03-21-2018 10:56 AM - edited 03-17-2019 12:27 PM
Hi Everyone
Is there any conditional command available for specify calling or called number ?
Instead of debug casip messages.
03-21-2018 05:02 PM
03-21-2018 11:35 PM
Hi Aeby,
I need to do cofigure conditional debug for called number in this case;
enable
configure terminal
call filter match-list number voice
incoming calling-number CAL_LIST_TEST
incoming called-number CAL_LIST_TEST
incoming secondary-called-number 344221155
incoming port string
incoming signaling {local | remote'} 'ipv4 ip_address
incoming media {local | remote'}' ipv4 ip_address
incoming dialpeer tag
source carrier-id string
source trunk-group-label group-number
outgoing calling-number string
outgoing called-number string
outgoing secondary-called-number string
outgoing port string
outgoing signaling {local | remote'}' ipv4 ip_address
outgoing media {local | remote'}' ipv4 ip_address
outgoing dialpeer tag
target carrier-id string
target trunk-group-label group-number
end
My call flow is that;
ip phone - sip - cucm- sip trunk- cube- sip trunk- itst.
Do i need to configure all related parameter such as trunk group or dial-peer and target carrier-id string ?
03-21-2018 11:42 PM
03-22-2018 06:04 AM
