11-17-2008 08:23 AM - edited 03-15-2019 02:35 PM
Hi all. I have a situation where there is a conference call setup, and when 4 calls come in, the rest of the people cant call in. There seems like there is a four call capability or something. Anyone heard of this?
Solved! Go to Solution.
11-17-2008 08:30 AM
Hi John,
Both Ad Hoc and MeetMe conferences have a configurable setting that limits the number of participants;
Clusterwide Parameters (Service)
Maximum Ad Hoc Conference = 4
Maximum MeetMe Conference Unicast = 16
The default number of Maximum MeetMe Participants (per Conference) is set at 4.
To increase the Maximum number of MeetMe participants (we have ours at 16);
Go to:
Service Parameters Configuration >Clusterwide Parameters (Service)>Maximum MeetMe Conference
Hope this helps!
Rob
11-17-2008 08:30 AM
Hi John,
Go to:
Hope this helps!
Rob
11-17-2008 10:44 AM
Just to point out that if you are using hardware conferencing resources the maximum number of participants in any conference (ad-hoc and meeme) is 8.
Chris
11-17-2008 11:07 AM
Thanks cderen to you as well. Good info that I will remember.
11-17-2008 01:26 PM
Hey Chris, I'm having trouble with the statement about hardware conf. resources max number of participants is 8. Can you clarify or point me to any docs that explain...appreciate it.
11-17-2008 01:32 PM
Sure.
If you are using hardware conferencing resources (PVDM modules in the router) they can only support 8 participants per conference bridge.
On the other hand the software conference bridge (CM server) can support up to 128 participant, however it only supports G711 codec and puts overahead on the server.
HTH,
Chris
11-17-2008 01:40 PM
Ok, I gotcha...I found a doc explaining the different types of Conf. Bridges:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_2/ccmsys/a05confb.html#wpxref58056
11-17-2008 11:06 AM
Rob, my friend, you nailed it on this. Thanks! I feel like the more I get into this forum and the more I run into "issues", the dumber I realize I am at VoIP. I appreciate the help and guidance and the help.
11-17-2008 12:30 PM
Hey John,
First off, you are always welcome! Secondly, don't beat yourself up here. This is a "never ending" learning curve with this stuff, I always feel like I'm moving one step forward and two steps back ;-)
The important thing is to keep learning and trying to get better. On some of the "old" systems that I worked on you could really learn them inside and out, but I never feel that way with IPT. I just keep plugging away.
Cheers!
Rob
11-17-2008 03:50 PM
Thanks for the encouragement Rob. I appreciate it.
11-18-2008 05:02 AM
Thank you :) that helped
