Conference does not work CME 10.0 2911 PVDM 32 phone sip
fdamian01
Hi conference functionality does not work in 2911 with PVDM32
all are SIP Phones (7800)
In the 7800 model phones I have an active call between two users
User B Extension: 1234
User B Extension: 4321
I press the conference button on the user B
I introduce the phone number to get into the conference (User Extension C: 6789)
The user C answers
Again I press the button conferencing on the user B conference
A conference between the two last numbers (user B and user C) it is created
UserA A is put on hold is not integrated to the conference
I have configured hardware conference in Telephony service and also in Global Voice register
CONFIG (Version=10.0)
Version 10.0
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 172.16.1.1 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup gpickup
service dnis dir-lookup
no auto-reg-ephone
max-ephones 58
max-dn 58
max-conferences 3 gain -6
dspfarm units 5
dspfarm transcode sessions 5
dspfarm 1 CME-CONF
dspfarm 2
dspfarm 3
dspfarm 4
dspfarm 5
conference hardware
conference transfer-pattern
SHOW VOICE REGISTER GLOBAL
Version 10.0
Mode is cme
Max-pool is 55
Max-dn is 55
Outbound-proxy is enabled and will use global configured value
Security Policy: DEVICE-DEFAULT
Forced Authorization Code Refer is enabled
Source-address is 172.16.1.1 port 5060
Authenticate register
Authenticate realm lab.local
NTP Server Address is 172.16.1.1
NTP Server Mode is: directedbroadcast
Time-format is 24
Date-format is D/M/Y
Time-zone is 9
Hold-alert is disabled
Mwi stutter is disabled
Mwi registration for full E.164 is disabled
Forwarding local is enabled
Video is disabled
Camera is enabled
Privacy is enabled
Privacy-on-hold is disabled
Conference hardware is enabled
Dst auto adjust is disabled
Voicemail number is 1000
Call List BLF is enabled
Max redirect number is 5
IP QoS DSCP:
Telnet Level: 0
Tftp path is flash:/its
Generate text file is disabled
Tftp files are created, current syncinfo 0005602083114343
OS79XX.TXT is not created
I have set an example annex transcoder and conferencing
dspfarm profile 2 transcode
codec g729r8
codec g729br8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
associate application CUBE
dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 1
This is the configuration of all my phones
voice register pool 1
lpcor type local
lpcor incoming end-user
busy-trigger-per-button 2
id mac 204C.9EB3.4225
type 7861
number 1 dn 1
cor incoming Nivel11 default
presence call-list
dtmf-relay rtp-nte sip-notify
username 1 password 79161
description 7861
codec g711ulaw
conference add-mode creator
conference admin
SHOW DSPFARM ALL
GNP_GATEWAY#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 2, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : CUBE Status : ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 2
Number of Resources Out of Service : 0
Number of Resources Active : 0
Codec Configuration: num_of_codecs:6
Codec : g729r8, Maximum Packetization Period : 60
Codec : g729br8, Maximum Packetization Period : 60
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Profile ID = 1, Service = CONFERENCING, Resource ID = 2
Number of Resource Configured : 1
Maximum conference participants : 8
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 1 35.1.8 UP N/A FREE xcode 1 - - -
0 1 35.1.8 UP N/A FREE conf 2 - - -
Total number of DSPFARM DSP channel(s) 3
Apply the hw-hardware debug ephone and I get the following
000292: *Jan 24 12:40:49.355 Mexico: Check associated hwconf with callid 348
000293: *Jan 24 12:40:49.355 Mexico: Unable to associate a dn/chan with callid 348
000294: *Jan 24 12:40:49.355 Mexico: Check associated hwconf with callid 348
000295: *Jan 24 12:40:49.355 Mexico: Unable to associate a dn/chan with callid 348
000296: *Jan 24 12:41:11.771 Mexico: Check associated hwconf with callid 348
000297: *Jan 24 12:41:11.771 Mexico: Unable to associate a dn/chan with callid 348
000298: *Jan 24 12:41:11.771 Mexico: skinny_hwcfb_check_resource: for Audio
000299: *Jan 24 12:41:11.771 Mexico: skinny_hwcfbi_find_next_mtpcb No conference MTPCB for device type 52:Audio only Fail
Annex sh logging and sh run
which is my configuration error?
They know something about this error?
Regards.
2 Accepted Solutions
Jaime Valencia
Because you're a lacking a LOT of the configuration required, that's why it's not working.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmeconf.html
java
if this helps, please rate
Vivek Batra
1. Change the application cube to application sccp.
2. There is no sccp group configuration. Please add it.
3. Then add sccm ccm command to associate sccp group with respective priority and cme ip address.
4. Add ephone-dn octo line with 'number AAAA' and 'conference ad-hoc' keyword.
Verify the status of dspfarm using show sccp or show dspfarm profile 1 command.
- Vivek
11 Replies 11
Jaime Valencia
java
If I have much to configure, thank you very much.
Vivek Batra
- Vivek
thanks I'll put it to practice and I give my results =)
You are configuring CUBE LTI for transcoding and conferencing. This won't work in your scenario because the media resources aren't invoked by the CUBE. They are invoked using Call Control Agent (which is CME).
Therefore, you media resources should register with CME rather than CUBE. Physically CUBE & CME are using the same box but they are different processes running different roles.
From config side you can use the comments of the colleagues
Excellent detail and CME CUBE Thanks
fdamian01
I already did the missing configuration, but still the same error, not join calls
voice-card 0
voice-service dsp-reservation 84
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
ipv4 172.16.1.0 255.255.255.128
ipv4 172.16.1.2
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
signaling forward unconditional
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
call start slow
call preserve limit-media-detection
sip
bind control source-interface GigabitEthernet0/0.23
bind media source-interface GigabitEthernet0/0.23
registrar server expires max 3600 min 3600
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 5
voice class custom-cptone leavtone
dualtone conference
cadence 400 150 400 100 400 50
voice class custom-cptone jointone
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
lpcor type local
id mac 204C.9EB3.4333
type 7861
number 1 dn 1
presence call-list
description 7861
codec g711ulaw
conference admin
sccp local GigabitEthernet0/0.23
sccp ccm 172.16.1.1 identifier 100 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0.23
associate ccm 100 priority 1
associate profile 1 register confdsp1
keepalive retries 5
codec g729r8
codec g729br8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 2
associate application SCCP
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 1
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm transcode sessions 5
sdspfarm tag 1 CME-CONF
sdspfarm tag 2 confdsp1
conference hardware
GATEWAY# sh dspfarm all
Profile Operation State : ACTIVE IN PROGRESS
Application : SCCP Status : ASSOCIATION IN PROGRESS
Application : SCCP Status : ASSOCIATED
GATEWAY#sh sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0.23
IPv4 Address: 172.16.1.1
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 172.16.1.1, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 100
Trustpoint: N/A
Transcoding Oper State: DOWN - Cause Code: NOT_ASSOC_TO_CCM_GROUP
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 2
Reported Max Streams: 4, Reported Max OOS Streams: 0
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 172.16.1.1, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 8, Reported Max OOS Streams: 0
TLS : ENABLED
043114: *Jan 25 09:47:48.678 Mexico: Unable to associate a dn/chan with callid 2538
043115: *Jan 25 09:47:58.938 Mexico: Check associated hwconf with callid 2538
043116: *Jan 25 09:47:58.938 Mexico: Unable to associate a dn/chan with callid 2538
043117: *Jan 25 09:48:03.226 Mexico: Check associated hwconf with callid 2528
043118: *Jan 25 09:48:03.226 Mexico: Unable to associate a dn/chan with callid 2528
043119: *Jan 25 09:48:03.226 Mexico: skinny_hwcfb_check_resource: for Audio
043120: *Jan 25 09:48:03.226 Mexico: skinny_hwcfbi_find_next_mtpcb Got MTPCB conference type req 52:Audio only as Audio only Pass
NO, you have NOT configured all you need, you need to take a really close look to the configuration links!!, I suggest you read the whole link, and digest the information, before attempting to do the configuration.
You're missing the last step Vivek mentioned, which is also covered in the link I provided.
java
JaVa has correctly mentioned twice here. Reading a document will give you enough info not only about 'how to', but will also help you to troubleshoot the subject as and when required.
Please add ephone-dn confirmation.
- Vivek
thanks worked with add ephone-dn =)
Thanks for updating us back.
- Vivek
