Conference issue using Intercluster trunk GK controlled
acerda
Hi All
<br />Scenario is when I try to connect tow remote phone in a conference started in one cluster the call drop.
<br />No log are registred on the voice gateway that is giving the DSP and XCODE, I am using debug sccp events or errors.
<br />The transcoders are up and registered on the CCM.
<br />
<br />sccp ccm group 1
<br /> bind interface Loopback1
<br /> associate ccm 1 priority 1
<br /> associate profile 1 register AA-HW-CONF1
<br />!
<br />dspfarm profile 1 transcode
<br /> codec g711ulaw
<br /> codec g711alaw
<br /> codec g729ar8
<br /> codec g729abr8
<br /> maximum sessions 28
<br />
<br /> associate application SCCP
<br />!
<br />dspfarm profile 2 conference
<br /> codec g729r8
<br /> codec g729br8
<br />
From the other side (cluster) the conference via ICT working well.
<br />Please advise any suggest.
<br />Regards
<br />Andres
ivillegas
Level 6
Level 6
What version of ccm is involved on both sides of the cluster?
Are calls failing in both directions?
post the following from the gatekeeper:
show version
show run
show gateway
Resetting a trunk drops any calls in progress that are using that trunk. Restarting a gateway tries to preserve the calls in progress that are using that gateway, if possible. Other devices wait until calls complete before restarting or resetting. Resetting/restarting an H.323 or SIP device does not physically reset/restart the hardware; it only reinitializes the configuration that is loaded by Cisco Unified CallManager.
ivillegas
Level 6
Level 6
show version
show run
show gateway
Thxs a lot for your comments
Andres
