Conference Issue
opnineopnine
Hi all,
I’m having the following issue, when the customer is having a conference sometimes the 3er person in the call is not hiring the other 2 in the call,
This is occurred when the 3er person is called out of the company.
What debug can I use to check where the problem can be?
thanks.
Jaime Valencia
Sounds like codec issues, and FYI, you need to mention what system, and version, you have when asking help.
java
if this helps, please rate
Jaime,
This is a cucm 8.6
dspfarm profile 10 transcode
 codec g729br8
 codec g729r8
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 maximum sessions 28
 associate application SCCP
dspfarm profile 20 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711ulaw
 codec g711alaw
 maximum sessions 11
And does your configuration points to use those??
You would need to review CUCM traces to find the reason for the disconnection.
java
