conference list
Pawan Arora
Is there a way to see the conference list on 6921 and 6941 IP phone and remove the participants from the conference?
Pawan Arora
8 Replies 8
V.Naveen Kumar
For viewing Conference Participants:
   While in a conference, press the Details softkey to view a list of the last 16 participants who have joined the conference.
For Remove participants:
While in a conference, press the Details softkey to view a list of participants.
Highlight the participant that you want to remove, then press the Remove softkey.
HI Naveen,
thanks for the informaiton, but I am unbale to see the remove key after pressing the details softkey.
Pawan Arora
In the Ephone, use the following command
conference admin
Then try again.!!
Hi Abhnay,
I am using Call manager 8.6.2
regards,
Pawan Arora
Pawan Arora
Hi All,
Issue has been resolved after upgrading the firmware of the phones.
Thanks for your support.
Pawan Arora
Hi Pawan,
Are you running CME or CM server?
I have the same problem with CME 9.1
regards
Hi Filiberto,
I am using CM server 8.6.2.
Pawan Arora
Dear:
What firmware use???
I have the same problem with the 8961 and 8941 phones and the upgrade the firmware but not works.
Thanks for your help.
