12-07-2012 02:15 PM - edited 03-16-2019 02:37 PM
Hi all guys, i have an issue an need some help and orientation, thnk for now.
Site 1
CUCM sub
phone A
phone B
Site 2
phone C
Router 3925 --> v 15.2(2)T --> PVDM3-256
SItuation:
the idea is when the phone c want to start a conference it ask resources from the 3925 router and don´t from cucm cross the wan.
the call is stablishd between phone a and phone c with no problemas, good quality, right audio, etc. Phone C begin to start a conference, press conf, call phone b, and then press conf again for stablish the conference..... the conference is stablished but with no audio at all, in any direction. but
when one phone leave the conference the audio come back normaly between point to point call.
when the conference is hosted by the gateway, the audio flow between the phones and gateway. i dont know what could be.
thank for you help, and i attach show run and show ver
regards
12-07-2012 02:39 PM
Issue the command "show sccp" you should see the Conferencing Oper State: ACTIVE
It should also show the active call manager that the conference profile is registered with and the TCP link status should show CONNECTED along with all the supported codecs you have configured.
On the call manager side did you configure the conference bridge as Cisco IOS Conference Bridge or Enhanced Cisco IOS Conference Bridge when creating this? If you used the hardware option I dont think this will work in this scenario.
And your transcoder is in shutdown.
Tracy
12-07-2012 02:45 PM
On another quick note, everyone here is trustworthy I know - but you should really take out your passwords, usernames and ip addresses when posting configs. Password 7 is very easy to crack.
12-08-2012 05:59 AM
hi tracy, you righ about the passwords, sorry my mistake.
about configuration:
i attach sh sccp, everythink looks good.
in the cucm i registered cfb like Enhanced Cisco IOS Conference Bridge.
and, its necesary that transcoder is UP ?
i shutdown only for test cfb, but when the transcoder is UP nothing change.
i registered the transcoder in CUCM like Enhanced Cisco IOS Conference Bridge
10.6.1.10: Subscriber
ARGLAMGW01#sh sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0
IPv4 Address: 10.8.98.6
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 10.6.1.10, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 1
Trustpoint: N/A
Call Manager: 10.6.129.248, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 2
Trustpoint: N/A
Call Manager: 10.8.98.6, Port Number: 2000
Priority: N/A, Version: 7.0, Identifier: 3
Trustpoint: N/A
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 10.6.1.10, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 160, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
TLS : ENABLED
thanks for you help tracy:)
regards.
12-08-2012 02:14 PM
Aqustin,
Can all phones ip connect with the
cnf bridge address 10.8.98.6
Check with pings ec
Alex.
Please rate useful posts.
12-10-2012 07:04 AM
Hi Alex,
yes all phones that i put in the MRGL with my Hw CFB 10.8.96.6 can connect to it.
