Conference now announcements
paulwilsonvm
Conference now on CUCM v11 is not playing the default announcements but announmencements all work if I upload custom ones.  Any ideas?
7 Replies 7
bernhardczapp
Level 4
Level 4
Are the appropriate locales installed?
not sure which locales are required for this?
Thanks for this
Paul
That was the issue thats a lot!
Can you elaborate on this?  What locales are they referring to and where do you install/select them?
  1. check this out http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-version-71/113395-cucm-locale-nl-00.html
I just installed the GB one as I'm in the UK and now get the british announcements
where i can find the correct file for version 11?
Check the below link:
https://software.cisco.com/download/release.html?mdfid=286284802&flowid=77897&softwareid=282074333&release=11.0(1.1000-1)&relind=AVAILABLE&rellifecycle=&reltype=latest
Rajan
