12-07-2015 12:23 AM - edited 03-17-2019 05:08 AM
I'm working on configuring Video conferencing bridge on Cisco 2921 router , but i can't add the command part : "video homogeneous" in the "dspfarm profile 1 conference " command
Do youy have any suggestions .
Ahmed
Solved! Go to Solution.
12-07-2015 03:28 AM
You seem to be on 15.1(3)T4 and respective command is available from 15.1(4)M. IMO you need to upgrade IOS else wait if Deji has some other point on it.
- Vivek
12-07-2015 12:54 AM
Please check and verify the following configuration;
voice-card x
dspfarm
dsp services dspfarm
voice-service dsp-reservation xx
- Vivek
12-07-2015 01:42 AM
Thanks Vivik , they are inserted but i can't also add the reservation command (command unrecognized )
12-07-2015 02:23 AM
What IOS are you running..
Can you send
sh version
sh diag
12-07-2015 02:51 AM
12-07-2015 03:28 AM
- Vivek
12-07-2015 03:36 AM
Many thanks Vivik .
Ahmed
12-07-2015 02:28 AM
Please note that video conferencing is supported since 15.1(4)M till 15.5(3)M. On which version you are?
http://www.cisco.com/c/en/us/products/collateral/unified-communications/tdm-gateways/bulletin-c25-735945.html
- Vivek
12-07-2015 05:51 AM
Ahmed, please note that Video conferencing and transcoding on the PVDM3 modules is not longer supported by Cisco. The alternative solution for the customers now is to move to the Cisco TelePresence Multipoint Control Units (MCUs) which are being marketed as the solution for video conferencing and also support transcoding.
12-10-2015 01:45 AM
Hi Sreekanth
Thanks , i got that response from them .
even they gave it a bug ID : CSCus97643
Ahmed
