10-15-2020 03:10 AM
I have CUCM 12.5(1)SU3 and users want to use Conference Now.
I import the users from LDAP and have created a Feature Group Template that enables Conference Now for imported users but the Attendees Access Code for the users is blank and I have to set it manually.
Is there a way to assign a default value for this? - the Feature Group Template does not allow this and I cannot find any other way to set it (Service Parameter, User Profile etc.)
10-15-2020 04:13 AM - edited 10-15-2020 04:27 AM
You can set this with a Bulk update of users with a custom file.
The highlighted part would be what you need to set.
I haven't tried it myself, but likely this would be the format of the file you need.
USER ID,ENABLE END USER TO HOST CONFERENCE NOW,MEETING NUMBER,ATTENDEES ACCESS CODE UserIDtoUpdate,t,123456789,5678
10-15-2020 04:24 AM
Roger,
Thanks for the response. I was hoping that it could just be set as a default value similar to how a PIN can be.
It is not a massive issue and it looks like it is not possible so I will probably follow your suggestion when I import the bulk of the users and tell the admin to do it manually when new users are imported.
Thanks again
