Conference Now T-Shoot
RAustin70
I have conference Now enabled on my 1-Pub 2-Sub 2-TFTP CUCM 11.5.x system.  Service Parameter Maximum MeetMe Conference Unicast is set to 50, and end users (hosts) are configured correctly.
Twice in the past couple weeks, I have received trouble calls stating that after 9-12 connections, the system would not allow anymore.  The attendee calls in to an active meeting with Host active, enters the meeting number, enters the PIN, and the call just drops.  This occured to both PSTN Attendees and OnCluster Attendees
Where can I look to see what could be causing this?  CDR records of the conf shows nothing out of the ordinary, as does the RTMT Realtime data on the calls.  During the calls, maybe 5 other conference now sessions are happening each with 3-6 attendees each, not maxed out in the least.
OK, and what's the maximum participant/conferencees setting on your dspfarm profile?
java
if this helps, please rate
5 Replies 5
Jaime Valencia
What do you use for CFB?
CUCM's SW CFB? IOS? CMS?
java
I have 2 IOS CFB on ISR 4431's with PVDM4-256 in slot 0/1 & PVDM4-128 in slot 0/2.  and I have my 2 tftp servers registered as software CFB's.  The MRGL is set up to run hardware first.
The ISR's are also my Voice gateways, HW XCODE & MTP,
java
AH HA!!!  Jamie you are always THE man!
Profile ID = 1, Service = CONFERENCING, Resource ID = 2
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Total Number of Resources Configured : 15
Total Number of Resources Available : 14
Total Number of Resources Out of Service : 0
Total Number of Resources Active : 1
Maximum conference participants : 8
Codec Configuration: num_of_codecs:6
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
Dspfarm Profile Configuration
I am thinking this could be the cause lol.  Taking CIPTV1 this friday, was going to do CAPPS next month, my be better if I try the Troubleshoot haha.  Now to figure out the best way to increase this without overworking the device.
dspfarm profile 3 transcode
description XCODE
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g729r8
maximum sessions 30
associate application SCCP
dspfarm profile 900 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
shutdown
dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 15
dspfarm profile 2 mtp
description MTP
codec g711ulaw
codec pass-through
maximum sessions software 100
Profile ID = 3, Service = TRANSCODING, Resource ID = 1
Profile Description : XCODE
Total Number of Resources Configured : 30
Total Number of Resources Available : 30
Total Number of Resources Active : 0
Codec Configuration: num_of_codecs:5
Profile ID = 900, Service = TRANSCODING, Resource ID = 4
Profile Admin State : DOWN
Profile Operation State : DOWN
Application : None Status : NOT ASSOCIATED
Resource Provider : FLEX_DSPRM Status : NONE
Total Number of Resources Configured : 0
Total Number of Resources Available : 0
Codec Configuration: num_of_codecs:4
Profile ID = 2, Service = MTP, Resource ID = 3
Profile Description : MTP
Resource Provider : NONE Status : NONE
Total Number of Resources Configured : 100
Total Number of Resources Available : 100
Hardware Configured Resources : 0
Hardware Resources Out of Service: 0
Software Configured Resources : 100
Number of Hardware Resources Active : 0
Number of Software Resources Active : 0
Codec Configuration: num_of_codecs:2
Codec : pass-through, Maximum Packetization Period : 0
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0/1 3 46.2.8 UP 1 USED conf 2 233180 338558 338554
0/1 3 46.2.8 UP 1 USED conf 2 233190 326635 326634
0/1 3 46.2.8 UP 1 USED conf 2 233198 321921 321920
0/1 3 46.2.8 UP 1 USED conf 2 233205 318038 318038
0/1 3 46.2.8 UP 1 USED conf 2 233208 317006 317005
0/1 3 46.2.8 UP 1 USED conf 2 233217 307776 307775
0/1 3 46.2.8 UP N/A FREE conf 2 - - -
0/1 4 46.2.8 UP N/A FREE conf 2 - - -
0/2 1 46.2.8 UP N/A FREE xcode 1 - - -
0/2 2 46.2.8 UP N/A FREE xcode 1 - - -
0/2 2 46.2.8 UP N/A FREE conf 2 - - -
Total number of DSPFARM DSP channel(s) 45
