02-13-2008 06:24 AM - edited 03-15-2019 08:48 AM
We have CCM 4.1(3) in Greece, it dials out via an H323 gateway which is enabled on a 2811 series router, IOS version - 12.3(11)T2.
Problem - Internal conferencing works fine, but international conferencing doesn't. Suppose someone outside the cluster calls from US to Greece, the call is setup & then if the user wants to join another caller, say from Britian on a con call it doesn't work. Can something be done about this, I mean enabling off-cluster conferencing?
Solved! Go to Solution.
02-15-2008 02:17 AM
Thanks Dave, so I guess under the voip dial-peer I need to add " voice class codec 10 " to make sure everything is fine.
02-15-2008 02:28 AM
No problems,
Yes!
dial-peer voice x voice
That way it will try G.711 first instead of G789r8 which is the default codec for a voip dial-peer.
Dave
02-15-2008 02:59 AM
Thanks Dave,
Greatly appreciate the fact that you took so much time out of your busy schedule to help me out. Thanks & have a nice day & great weekend.
Thanks & Regards,
Abhijit Das.
02-15-2008 03:10 AM
Abhijt,
My pleasure.
Have a great weekend.
Dave
02-15-2008 06:02 AM
Dave, just one final thing regarding this issue - we don't have any transcoders configured anywhere. Think that should not make any difference here. Just wanted to double-check with you.
Abhijit Das.
