Configuration of E1/T1 to send data
fayiz husain
How to configure E1/T1 to send data? Can anyone give me the commands?
3 Accepted Solutions
ronpatel
Level 8
Level 8
HI
You can follow below link for configuring it from data networks
http://www.cisco.com/en/US/docs/ios/12_1/12_1xd/feature/guide/t1e1wan.html
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
You can use above document or below
http://www.cisco.com/en/US/docs/routers/access/1700/1721/software/feature/guide/t1e11721.html
Main command is channel-group 0 timeslots 1-31
Ronak Patel
Fayiz,
As Ronak has provided you the link, you need to configure Controller, then configure your Serial interface - assign it ip address/encapsulation depending on what you are trying to achieve.
For example: you can use to connect point to point link between two routers or use it as a backup solution or may be even connect to frame relay cloud (which is pretty much obsolete) etc. along with more options.
The exact commands will be according to your design what exactly are you trying to achieve, connecting two offices or configuring backup link, etc - its not very complicated. You can refer to the document provided or ask here again if you come across any issue.
-Terry
6 Replies 6
ronpatel
Level 8
Level 8
HI
Ronak Patel
Can you describe the call flow?
It will help us better
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
I need the commands to configure E1/T1 as WAN link?
Ronak Patel
+5 to you Ronak
Pls follow the link that Ronak Provided
chrysostomos
Fayiz,
-Terry
