02-25-2013 09:58 PM - edited 03-16-2019 03:56 PM
02-25-2013 10:05 PM
HI
You can follow below link for configuring it from data networks
http://www.cisco.com/en/US/docs/ios/12_1/12_1xd/feature/guide/t1e1wan.html
Ronak Patel
Rate all helpful post by clicking stars below the answer.
02-26-2013 12:53 AM
You can use above document or below
http://www.cisco.com/en/US/docs/routers/access/1700/1721/software/feature/guide/t1e11721.html
Main command is channel-group 0 timeslots 1-31
Ronak Patel
02-26-2013 02:58 AM
Fayiz,
As Ronak has provided you the link, you need to configure Controller, then configure your Serial interface - assign it ip address/encapsulation depending on what you are trying to achieve.
For example: you can use to connect point to point link between two routers or use it as a backup solution or may be even connect to frame relay cloud (which is pretty much obsolete) etc. along with more options.
The exact commands will be according to your design what exactly are you trying to achieve, connecting two offices or configuring backup link, etc - its not very complicated. You can refer to the document provided or ask here again if you come across any issue.
-Terry
02-25-2013 10:05 PM
HI
Ronak Patel
02-25-2013 11:32 PM
Can you describe the call flow?
It will help us better
chrysostomos
02-26-2013 12:24 AM
I need the commands to configure E1/T1 as WAN link?
02-26-2013 12:53 AM
Ronak Patel
02-26-2013 01:29 AM
+5 to you Ronak
Pls follow the link that Ronak Provided
chrysostomos
02-26-2013 02:58 AM
Fayiz,
-Terry
