Configure CUCM via AXL
Daniel Flieth
Hello guys,
i have a question to the AXL programming. Today i looked for tutorials to make a small programm, maybe just to configure one translation pattern.
But when i search at google, i´ve found only tutorials which dont show the whole process. (a step by step - from the beginning to the end - tutorial would be nice). Does anybody have such a tutorial?
If not, can you tell me whats the best guide to learn AXL Programming?
Best Regards
Daniel
Hey Aaron,
Translation Pattern worked fine. I also did this for adding Partitions and for adding CSS(including partitions).
But now when i try to update some ServiceParameters i dont see how the XML output should look like.
At the moment i did it like this:
public SOAPMessage createSOAPMessage() throws Exception {
        MessageFactory mf = MessageFactory.newInstance();
        SOAPMessage soapMessage = mf.createMessage();
        SOAPPart soapPart = soapMessage.getSOAPPart();
        SOAPEnvelope envelope = soapPart.getEnvelope();
        SOAPBody bdy = envelope.getBody();
        SOAPBodyElement bodyElement = bdy.addBodyElement(envelope.createName("updateServiceParameter", "axl", "
http://www.cisco.com/AXL/API/1.0
        Name attrUuid = envelope.createName("uuid");
        SOAPElement ServiceParameter = bodyElement.addChildElement("ServiceParameter");
        ServiceParameter.addAttribute(envelope.createName("sequence"), String.valueOf(System.currentTimeMillis()));
        ServiceParameter.addChildElement("name").addTextNode("TimerT302_msec");
ServiceParameter.addChildElement("value").addTextNode("8000");
return soapMessage; public SOAPMessage createSOAPMessage() throws Exception {
        SOAPBodyElement bodyElement = bdy.addBodyElement(envelope.createName("updateServiceParameter", "axl", "http://www.cisco.com/AXL/API/1.0"));
return soapMessage;
In the Documentation i see which fields i should use and via SQL i saw that the parameter is named TimerT302_msec, but i think i send it wrong to the CUCM.
Maybe you already programmed a script for update SP.
Best Regards
Daniel
Hi Daniel
According to the AXL API:
You need to specify a node name, param name, and service. You'd need to look closer at the spec or experiment a little in order to find the correct values for each.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
