configure forced authorization code at callmanager express
Support Albakom
Level 3
Level 3
hi,
is it possible to configure forced authorization codes at callmanger express or voicegateway in SRST? I  have an CUCM 7.1.3 with it and will configure it at the gateway in case of SRST.
Jaime Valencia
PLEASE, SEARCH the community for answers before posting a question. This has been asked plenty of times before.
https://supportforums.cisco.com/message/1203733#1203733
If you need more references just search CME + FAC and you'll get tons
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
