04-10-2014 09:08 AM - edited 03-16-2019 10:26 PM
Hello: I need to configure toll fraude prevention in three of my routers, Ios versions:
c880voice-universalk9-mz.124-24.T6.bin
c880voice-universalk9-mz.150-1.M8.bin
I used the following guide, which according to Cisco, is intended for ios version 12.1 or later:
This is the configuration I planned to use, but my routers do not support any of the commands under "voice service voip",
Router> enable
Router# configure terminal
Router(config)# voice service voip
Router(conf-voi-serv)# ip address trusted authenticate
Router(conf-voi-serv)#ip address trusted call-block cause call-reject
Router(conf-voi-serv)# ip address trusted list
Router(cfg-iptrust-list)#ipv4 10.0.0.0 255.0.0.0
Router(cfg-iptrust-list)#end
I have been seaching for equivalent commands but haven't found any.
Is there anyone with experience configuring toll fraud prevention for devices with IOS release older than 15.1(2). What am I doing wrong?
Thanks in advance!
04-10-2014 12:05 PM
This feature did not exist pre 15.1(2). If you need it I suggest you upgrade your IOS. There is no concept of toll fraud prevention in older IOS releases
04-10-2014 10:08 PM
As Ayodeji suggested, it is recommended to upgrade the IOS for this feature.
Or esle, you can try configuring Access-Lists to block the traffic coming from un-wanted IPs
