Configuring Cisco 8861 with Ovh
HiBou
 Trying to use my 8861 with Ovh account.
Parameters from ovh:
2018-06-19 16_59_38-Démarrer.png2018-06-19 17_01_53-Nouvelle notification.png
Ok @HiBou
Ovh advocate that:
- SIP ALG must be desactivated
- UDP session must be at least to 80 secondes.
- Trafic for networks 91.121.128.0/24 and 91.121.129.0/24 must be authorized on ports UDP/5060 - 5062 and 5080  and the range UDP from 30000 to 40000 also.
- Expiration time for phone's registering must be configured to 1800 secondes.
All are Ovh recommandations.
Check the usename/password and the domain name that Ovh gave you.
On your box if you have configured your fiewall....take care and check you rules.
Best regards
8 Replies 8
HiBou
The phone doesnt work ,thanks for help.
Regards.
Sam
Ok @HiBou
Check the NAT Mapping Enable --> yes
If it looks like better describe what has changed?
Best regards
After modification, SIP messages sent and Recv increase.
Line 1 (Ext1) is status Failed but don't understand why ?
Thanks for help.
Log extract :
0044 NOT Jun 20 10:09:36.441693 (16394:16459) voice- =====> Send [91.121.129.130]:5060 SIP MSG::  NOTIFY sip:sip4.ovh.fr SIP/2.0^M
	Via: SIP/2.0/UDP 192.168.0.26:5060;branch=z9hG4bK-ae068402^M
	From: "xxxxxxxxxxxxxxxxxxx;tag=385987468d0cec00o0^M
	To: <sip:sip4.ovh.fr>^M
	Call-ID: 44bed13a-51cd1078@192.168.0.26^M
	CSeq: 3661 NOTIFY^M
	Max-Forwards: 70^M
	Contact: "0033448060549" <sip:0033448060549@192.168.0.26:5060>^M
	Event: keep-alive^M
	User-Agent: 0033448060549^M
	Proxy-Require: sip4.ovh.fr^M
	Content-Length: 0^M
	^M
0045 NOT Jun 20 10:09:36.441720 (16394:16459) voice-::End-Of-Sip-Message::	 SIP MSG len=428
0046 NOT Jun 20 10:09:36.489466 (16394:16459) voice- <===== Recv [91.121.129.130]:5060 SIP MSG::  SIP/2.0 200 OK^M
	CSeq: 3661 NOTIFY^M
	From: "0033448060549" <sip:sip4.ovh.fr@sip4.ovh.fr>;tag=385987468d0cec00o0^M
	Via: SIP/2.0/UDP 192.168.0.26:5060;received=88.181.86.173;rport=5060;branch=z9hG4bK-ae068402^M
	Content-Length: 0^M
	^M
0047 NOT Jun 20 10:09:36.489524 (16394:16459) voice-::End-Of-Sip-Message::	 SIP MSG len=290
0048 NOT Jun 20 10:09:36.489690 (16394:16459) voice-SIP_tsClientEventProc(): ts=44feb150 tu=44fcce90(9), cb=7e5b8
@HiBou
In the menu Info and status.
The hostname biginning with SEPxxxx
The xxxx is the good.mac address?
Best regards
Yes it's the good mac adress
Ok @HiBou
Ovh advocate that:
Best regards
 That's work fine !
What I do : factory reset & simple chack all parameters & adding the sip username and password and..... I'm disapointed but the phone works immediately.
I Think the phone was not a "new phone" but a "repackaging" with bad configuration.
A BIG BIG THANKS to M02@rt37 for help.
Phone support for Cisco doesn't help me :(
Thanks again.
Sam.
Great!!!
Cisco Phone support are busy and perhaps not aware with your case.
I have already do what you have done with cisco phone and Ovh.
Thanks for your reply.
Best regards
