configuring DSP resources on router
littledavewhite
i have a ISR router running 12.4 software with a PVDM2-8, i want to configure the router as a conferencing only dsp, the dsp calculator suggests the follwing config
CLI Information for Optimal results.
To match the DSP Calculator configuration with your router, enter the following commands in configuration mode in your Cisco 2801 router:
Optimal Results
voice-card 0
codec complexity flex
Set of Conferencing/Transcoding commands when used with PVDM2-XX DSPs:
sccp local <local interface>
sccp ccm <call manager IP address> identifier <ccm ID #> version <version #>
sccp
sccp ccm group 999
bind interface <local interface>
associate cme <cme ID #> priority 1
associate profile <conferencing profile ID #> register <conference bridge name>
dspfarm profile <conferencing profile ID #> conference
maximum sessions 4
associate application SCCP
when i configure these setting it will only allow me to set max sessions to 1, this is the only option, but in the calculator recomendation it says 4 ? any clever people out there that may be able to shed some light on this.
This behaviour seems very perculiar, have you tried removing and re-applying the DSP profile?
When you removed the codecs did you shut the profile and re-apply SCCP? Firstly shutdown the profile, then shut sccp with a 'no sccp' from global, then re-apply 'sccp'. Once you have done this try creating the profile again ensuring that only G711 codecs are selected.
Can remove the dspfarm and re-create it with medium complexity, providing you remove the unwanted codecs from the list, this should still allow you 4 CFBs.
Allan.
9 Replies 9
allan.thomas
Level 8
Level 8
For flex complexity the PVDM2-8 will certainly support 4 G711 only Conference Bridges, the higher the complexity the less number of CFBs it can support.
The fact that you are only able to configure the maximum sessions to 1 suggests that you have voice-card/modules installed in the gateway. If this is the case then DSPs will be automatically reserved for these modules before you are able to configure your DSPFARM. Do you have such modules installed?
Please provide a 'show voice port summary'.
Allan.
hi alan
the show voice summary command
note we have no voice modules in the gateway, just a PVDM 2-8, we are using the gateway as srst just for local calls if wan fails, but no local pstn on gateway.
CS-CR-2801-GW#show voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
50/0/1 1 efxs up up on-hook idle y
50/0/2 1 efxs up up on-hook idle y
50/0/3 1 efxs up up on-hook idle y
50/0/4 1 efxs up up on-hook idle y
50/0/5 1 efxs up up on-hook idle y
50/0/6 1 efxs up up on-hook idle y
50/0/7 1 efxs up up on-hook idle y
50/0/8 1 efxs up up on-hook idle y
50/0/9 1 efxs up up on-hook idle y
50/0/10 1 efxs up up on-hook idle y
50/0/11 1 efxs up up on-hook idle y
50/0/12 1 efxs up up on-hook idle y
50/0/13 1 efxs up up on-hook idle y
50/0/14 1 efxs up up on-hook idle y
50/0/15 1 efxs up up on-hook idle y
50/0/16 1 efxs up up on-hook idle y
50/0/17 1 efxs up up on-hook idle y
50/0/18 1 efxs up up on-hook idle y
50/0/19 1 efxs up up on-hook idle y
50/0/20 1 efxs up up on-hook idle y
50/0/21 1 efxs up up on-hook idle y
50/0/22 1 efxs up up on-hook idle y
50/0/23 1 efxs up up on-hook idle y
50/0/24 1 efxs up up on-hook idle y
50/0/25 1 efxs up up on-hook idle y
50/0/26 1 efxs up up on-hook idle y
50/0/27 1 efxs up up on-hook idle y
50/0/28 1 efxs up up on-hook idle y
50/0/29 1 efxs up up on-hook idle y
50/0/30 1 efxs up up on-hook idle y
50/0/31 1 efxs up up on-hook idle y
50/0/32 1 efxs up up on-hook idle y
50/0/33 1 efxs up up on-hook idle y
50/0/34 1 efxs up up on-hook idle y
50/0/35 1 efxs up up on-hook idle y
50/0/36 1 efxs up up on-hook idle y
50/0/37 1 efxs up up on-hook idle y
50/0/38 1 efxs up up on-hook idle y
50/0/39 1 efxs up up on-hook idle y
50/0/40 1 efxs up up on-hook idle y
sccp local Loopback100
sccp ccm 172.31.10.1 identifier 1 version 4.0
sccp ccm 172.31.140.2 identifier 2 version 4.0
sccp
sccp ccm group 1
associate ccm 2 priority 2
associate ccm 1 priority 1
associate profile 1 register CHURCHSIDE-CONF
registration retries 20
registration timeout 30
keepalive retries 10
connect retries 30
connect interval 30
switchback method immediate
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
jbarcena
Level 9
Level 9
If I remember correctly the PVDM2-8 only has 1/2 DSP, the problem here is that a conference allocates a complete DSP that is why you are not allowed to configure more than 1 session. In order to have more sessions you will require more resources.
//Jorge
The PVDM2-8 is listed as having ½ a DSP because it has a DSP that has half the processing capacity of the PVDM2-16.
For example, if the DSP on a PVDM2-8 is configured for G.711, it can provide (0.5 * 8) bridges/DSP = 4 conference bridges.
When configured to accept both G.711 and G.729 calls, a single DSP provides 2 conferences because it is also reserving its resources for performing transcoding of streams.
Remove all codecs from the within the Conferencing profile with the exception of G711, and see what sessions are available then? Because you are using mixed codecs you are limiting the sessions.
Cisco 2801 routers use the following PVDMs:
•PVDM2-8 (1 DSP)
•PVDM2-16 (1 DSP)
•PVDM2-32 (2 DSPs)
•PVDM2-48 (3 DSPs)
•PVDM2-64 (4 DSPs)
Conferencing needs dedicated DSP resources. A DSP will support eight conference calls on a G.711 codec, or two conference calls on a G.729/G.711 configuration. (The PVDM2-8 will support four conference calls on G.711 or 1 conference call on G.729/G.711.) There is a maximium of eight participants per conference. Up to 30 conferencing calls can be supported on the Cisco 2801 routers.
The above is taken from the following document link:-
http://www.cisco.com/en/US/partner/docs/routers/access/1700/1751/software/feature/guide/dsp_cn.html
Allan.
Hi Alan
I already tried removing the other codecs but the same issue, only allows me to put one in ?
Allan.
hi alan thanks for your time on this post, i'm back on site tomorrow so will try and test your suggestions. I will let you know how i get on.
Hi Alan
it worked, shutting down the profile and sccp then removing the additional G729 codecs. I now have the option of 1 to 5 sessions for conferencing on the PVDM 2-8
Great work
Dave white
Great to know that it worked out for you, thanks for the rating and best of luck.
Best Regards
Allan.
