05-14-2015 10:11 AM - edited 03-17-2019 03:00 AM
I'm trying to configure EM on CME, but the "services" button doesn't works.
Bellow is the CME's configuration:
ip dhcp pool voice
network 10.0.0.0 255.255.255.0
option 150 ip 10.0.0.1
default-router 10.0.0.1
voice logout-profile 1
user 9999 password 9999
number 2000 type normal
voice user-profile 1
user cisco password cisco
number 1010 type normal
interface FastEthernet0/0
ip address 10.0.0.1 255.255.255.0
duplex auto
speed auto
telephony-service
authentication credential username password
max-ephones 5
max-dn 5
ip source-address 10.0.0.1 port 2000
service phone webAccess 0
timeouts busy 5
url authentication http://10.0.0.1/CCMCIP/authenticate.asp username password
cnf-file location flash:
user-locale U1 load CME-locale-pt_BR-Portuguese-7.0.1.1.tar
date-format dd-mm-yy
max-conferences 4 gain -6
web admin system name Admin password cisco
transfer-system full-consult
create cnf-files version-stamp 7960 May 13 2015 17:55:37
ephone-dn 1
number 1000
pickup-group 10
ephone-dn 2
number 2000
pickup-group 10
ephone 1
device-security-mode none
mac-address xxxxxxxx
ephone-template 1
type 7942
button 1:1
ephone 2
mac-address xxxxxxxxx
ephone-template 1
type 7945
logout-profile 1
I've already consulted the links listed bellow, but it still doesn't working:
https://supportforums.cisco.com/discussion/12410436/extension-mobility-cme-not-working
https://dreamforccie.wordpress.com/2010/07/24/extension-mobility-on-cme-virtualize-your-phone/
Thanks in advance for your help!
05-14-2015 02:27 PM
Have you reviewed the actual CME configuration guide?
05-15-2015 07:50 AM
Yes, here is the configuration guide link I reviewed:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
05-15-2015 08:00 AM
You are missing the ip http server command mentioned in the admin guide. Add it and check if it helps.
Manish
