IP Telephony and Phones
Labels
In UCCX 8.5 SU3, the rtcsqssummary table is not showing all CSQs, seems to be capped at 35.  Any idea why?We just recently had to complete the SU3 upgrade to resolve an issue with the rtcsqssummary  tables not updating after a hardware failure.  Seem...
Hi,I am configuring a SIP trunk on CME. In general this is quite simple, have done this before several times.The SIP trunk is registered correctly, there is a dial-peer pointing to the SIP provider.When I do a 'debug ccsip messages' I never see the S...
j.huizinga by Level 6
  • 1637 Views
  • 11 replies
Hi everyone, I am working on creating a SIP trunk between a CME and a non-clustered Unity Connection 10.5 box. The CME is connecting to the CUC box through a site-to-site VPN tunnel. I have also successfully configured the dial-peer as well as the ph...
Hi We have a sip invite coming from Lync with the first name and the last name. The call is being denied by the ITSP because they need a DID in the from field. From: <sip:glenn.orcutt@1.1.1.1>;tag=1207269~b2e7ab81-19a9-49f9-adaf-eb693f51e143-47259121...
Amit Shah by Level 1
  • 765 Views
  • 4 replies
We are currently running Call Manager 10.5, and most of our phones are 7962's. We have a need to have these be used from a home or other remote location not on our network.I see that these phones have settings to connect via VPN, but I'm hoping someo...
Resolved! RTMT Session Trace
Hi Guys,Wondering if you can helpI have 4 call manager nodes. when I try to get Real time data from them 1 works and the others don't. I get the errorCollecting session information from node XXX01.XXX.netCollecting session information from node XXX02...
