Configuring multiple MSN Numbers on BRI Interface
cpartsenidis
Hi everyone,
I've got an ISDN line with around 8 MSN numbers connecting to my BRI 0/0/0 interface.
I'm trying to configure the interface to answer only specific MSN numbers, but can only find the option to answer up to 2 numbers using isdn answer1 <number1> & isdn answer2 (number2).
Any idea how this can be done?
Any help is much appreciated.
18 Replies 18
Paolo,
Correct me if I am wrong, but I can only define one destination-pattern under each dial-peer, or use a pattern that matches all incoming numbers e.g destination-pattern 210....... (
In this new case, I've defined a generic pattern that catches all possible patterns I need (210500501, 210500502 e.t.c).
I don't understand what additions I must make to get the new scenario working;
An example based on the configuration below would be much appreciated:
voice translation-rule 2
rule 1 reject /210500500/
voice translation-profile dropmsn
translate called 2
voice-port 0/0/0
translation-profile incoming dropmsn
dial-peer voice 400 voip
voice-class codec 1
session target ipv4:10.0.0.1
Seems fine, all numbers beginning with 210 and six more digits are sent to 10.0.0.1
However, for some reason, 210500500 is not being rejected.
I also tried adding the translation-profile to the dial-peer you saw, but the system still answers 210500500!
Any further ideas ?
Check ouput of "debug isdn q931" with "term mon". Worst case you can route the number to a fake IP and it won't answer.
