configuring translation Rules and dial-peer
need help with dial-peer and translation patterns
i have sip line connecting to VG2921 at branch connected to CUCM over HQ VG 2811.
incoming calls are working fine with number 8062300 which will land on ext 2300
i want all incoming calls should go to 3080 which is Auto Attendent.
i tried but not able to configure that please can anyone help me with that
voice translation-rule 1
rule 1 /^5\(........\)/ /05\1/
rule 2 /^1\(.......\)/ /01\1/
rule 3 /^2\(.......\)/ /02\1/
rule 4 /^3\(.......\)/ /\1/
voice translation-rule 2
rule 1 /8062300/ /3080/
voice translation-rule 3
rule 1 /^[2-3].../ /8062300/
voice translation-rule 4
rule 1 /^03\(8062300\)/ /3080/
voice translation-rule 5
rule 1 /^77\(.......\)/ /\1/
rule 2 /^77\(.........\)/ /\1/
rule 3 /^77\(............\)/ /\1/
rule 4 /^77\(..........\)/ /\1/
voice translation-rule 6
rule 1 /^238\(.\)/ /03806\1/
voice translation-profile INCOM_SIP
translate calling 1
translate called 2
voice translation-profile INCO_SIP
translate calling 1
translate called 4
voice translation-profile OUT-SIP
translate calling 3
translate called 1
dial-peer voice 15 voip
description incoming From ITSP Server to CUCM
translation-profile incoming INCOM_SIP
destination-pattern ^80623..$
progress_ind progress enable 8
session target ipv4:192.168.12.189
voice-class codec 1
dtmf-relay rtp-nte h245-signal h245-alphanumeric
no vad
dial-peer voice 10 voip
translation-profile incoming INCO_SIP
rtp payload-type cisco-codec-fax-ack 111
rtp payload-type nte 97
session protocol sipv2
incoming called-number ^80623..$
codec g711alaw
no vad
dial-peer voice 40 voip
destination-pattern ^0380623..$
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 30 voip
description To CallManager - SBWPMPUB
destination-pattern 3080
session target ipv4:192.168.12.190
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 31 voip
description to Callmanager-subscriber
preference 1
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 20 voip
description ***TO-LOCAL***
translation-profile outgoing OUT-SIP
destination-pattern .T
session target ipv4:10.205.20.50:5060
session transport udp
voice-class codec 1
dtmf-relay rtp-nte digit-drop
no vad
dial-peer voice 305 voip
rtp payload-type nte 98
session target sip-server
incoming called-number 8062300
voice-class codec 1
dtmf-relay rtp-nte
no vad
5 Replies 5
Chris Deren
So, should every single call go to 3080 or all calls except for 2300?
If all calls your TR should be very simple as:
rule 1 /.*/ /3080/
translate calling 1
translate called 2
then apply it to the incoming dial-peer from SIP provider.
Chris
thankyou Mr.Chris,
Tried the commands but still the call ringing at ext 2300 not going to 3080
Anas Abueideh
Level 9
Level 9
you need to configure
rule 1 // /3080/
if it is not working, use debug dialpeer all to check your matched dialpeers
Anas
please rate if it is helpful
Thankyou Mr.Anas
The debug voip dial peer all doc attached
dial peer 15 and 20 both are matching and while 20 is for outgoing.
Hi Mohammed,
you have issues with overlapping between the dial-peers. first you need to differentiate between incoming and outgoing dial-peers.
please apply the below config
voice service voip
  allow h323 to h323
  allow sip to sip
  allow sip to h323
  allow h323 to sip
rule 1 // /3080/
description ***Incoming called-number***
voice-class codec 1
no vad
dial-peer voice 21 voip
voice-class codec 1
no vad
incoming called-number .
destination-pattern [23]...$
voice-class codec 1
voice-class h323 1
no vad
preference 1
voice-class codec 1
voice-class h323 1
no vad
Anas
