Connecting CM 6.0 with Siemens HiPath 4000 Release 3.0 using SIP Trunk
ysanadiga01
I want to connect Cisco CM 6.0 to Siemens HiPath 4000 Release 3.0 using a SIP trunk. The Siemens HiPath got a built-in SIP trunk module and authentication is done on IP basis.
There is no problem when we are calling from Cisco to Siemens. But when calling from Siemens to Cisco, the Cisco CallManager gives a http 400 bad-request back. Maybe this is caused due to a misconfiguration on either Cisco or Siemens side.
Did someone configure Cisco CM 6.0 and Siemens HiPath 4000 using SIP trunk module? Any help will be highly appreciated.
Kind regards,
Sana
6 Replies 6
gogasca
Level 10
Level 10
Hi upload your CCM detailed trace include calling, called party number and timestamps and I can help you with this.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml#calm
Check CSS for SIP Trunk, MTP, codec, etc...
I check for interop guides and only see Q.SIG and Siemens HiPath 4000.
Hi, did you get this to work CCM to Siemens SIP
thanks
hello, it didn't work for me.
thanks
samamallareddy
Is your SIP Trunk working.I am planning to implement SIP trunk bitween Siemens Hipath 4000 to Call Manager 7.0 . Can you send the config details to my id
samamallareddy@gmail.com
thanks....
Sama,
You might want to check the following document, which has configuration steps required for "
Siemens HiPath 4000 Release 5.0 using SIP trunk to Cisco Unified Communications Manager 8.5  ". Even though it is for CUCM 8.5, procedure should change a lot.
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns784/984209.pdf
Whole lot of such documents are listed here at Cisco Interoperability Portal. http://www.cisco.com/en/US/solutions/ns340/ns414/ns728/networking_solutions_products_genericcontent0900aecd805b561d.html
Pls rate the post if it helps.
GP.
GP,
Thanks for the info. I have already configured SIP Trunk bitween Hipath 4000 V5.0 and CUCM V7.0 through CUBE( ISR 3845), But i am not able to call both sides.
If you have any specific supported document for config. pls let me know and also let me know is their any specific CUBE IOS version required to setup this SIP Trunk solution.
Thanks in advance
Sama
