Showing results forĀ
Search instead forĀ
Did you mean:Ā
connecting modem 56k with FXS port under 2801 router
adnane dakna
can somebody tell me if FXS port support connection with modem with 56 k rate.
5 Replies 5
paolo bevilacqua
Yes, but you must have the interface to telco in the same router.
fb_webuser
Level 6
Level 6
yes, its like using a common telephone switch, that can take out the calls to the pstn via FXS or T1. What I have not done yet is to pass the call throug an IP network, would be fun to pass IP over voice over IP over a digital or analog line. LoL
Posted by WebUser Milo Elchingon Dechingones
VoIP doesn't work good on modems, mainly because the upload is too slow.
However using extreme codecs, it can be done.
Th architecture Look like:
Is there any configuration to adjust in GateKeeper and router to get modem working
As indicated above. You cannot have high speed modem using two different gateways.
