Connecting two CME's for two offices
Eidy.jerjes1
I am new to CME, I have two offices (located less than 100 meters) both offices have CME 2900 series Version 15.2(4)M3 and more than 40 phone extensions.
I have one cable to connect between offices.
office 1 : phone extension starts 201
office 2: phone extension starts 301
employees on both offices should be able to call local extensions and other office extensions. Both offices are working separately now with below config.
Office #1
ip dhcp pool Voice
 network 10.10.10.0 255.255.255.0
 option 150 ip 10.10.10.10
 default-router 10.10.10.10
ip dhcp pool Data
 network 10.10.11.0 255.255.255.0
 default-router 10.10.11.10
 dns-server 10.10.11.9
interface GigabitEthernet0/0
 description Connected to Switch Trunk G0/48
 no ip address
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/0.10
 encapsulation dot1Q 10
 ip address 10.10.10.10 255.255.255.0
interface GigabitEthernet0/0.20
 encapsulation dot1Q 20
 ip address 10.10.11.10 255.255.255.0
interface GigabitEthernet0/1
escription Connected to Internet
 ip address 192.168.1.253 255.255.255.0
 ip nat outside
 duplex full
 speed 100
ip nat inside source static 10.10.11.60 192.168.100.233
ip route 0.0.0.0 0.0.0.0 192.168.1.254
voice-port 0/0/0
 supervisory disconnect dualtone mid-call
 timeouts call-disconnect 15
 timeouts wait-release 15
 timing hookflash-out 50
 connection plar opx 201
 caller-id enable
 caller-id alerting dsp-pre-allocate
voice-port 0/0/1
 caller-id enable
voice-port 0/0/2
 caller-id enable
voice-port 0/0/3
 caller-id enable
dial-peer cor custom
 name calllocal
 name callmobile
 name callint
 name ISP
dial-peer cor list call-local
 member calllocal
dial-peer cor list call-mobile
 member callmobile
dial-peer cor list call-int
 member callint
dial-peer cor list localuser
 member calllocal
dial-peer cor list mobileuser
 member calllocal
 member callmobile
dial-peer cor list superuser
 member calllocal
 member callmobile
 member callint
 member ISP
dial-peer cor list ISP
 member ISP
dial-peer voice 937 pots
 corlist outgoing call-mobile
 destination-pattern 9[3-7].......
 port 0/0/0
dial-peer voice 931 pots
 port 0/0/1
dial-peer voice 932 pots
 port 0/0/2
dial-peer voice 933 pots
 port 0/0/3
gatekeeper
 shutdown
telephony-service
 max-ephones 42
 max-dn 45
 ip source-address 10.10.10.10 port 2000
 auto assign 1 to 45
 max-conferences 8 gain -6
 web admin system name admin password 123
 transfer-system full-consult
 secondary-dialtone 9
 create cnf-files version-stamp 7960 Mar 02 2016 10:47:34
ephone-dn  1  dual-line
 number 201
 label 201
 name Reception
 call-forward noan 223 timeout 10
ephone  1
 no multicast-moh
 button  1:2
Office 2
ip dhcp pool Voice
 network 10.20.10.0 255.255.255.0
 option 150 ip 10.20.10.10
 default-router 10.20.10.10
ip dhcp pool Data
 network 10.20.11.0 255.255.255.0
 default-router 10.20.11.10
 dns-server 10.20.11.9
 no ip address
 ip nat inside
 duplex auto
 speed auto
 ip address 10.20.10.10 255.255.255.0
 ip address 10.20.11.10 255.255.255.0
 ip nat outside
 duplex full
 speed 100
ip nat inside source static 10.20.11.60 192.168.100.233
voice-port 0/0/0
 connection plar opx 301
 caller-id enable
voice-port 0/0/1
 caller-id enable
voice-port 0/0/2
 caller-id enable
voice-port 0/0/3
 caller-id enable
 name calllocal
 name callmobile
 name callint
 name ISP
 member calllocal
 member callmobile
 member callint
 member calllocal
 member calllocal
 member callmobile
 member calllocal
 member callmobile
 member callint
 member ISP
 member ISP
 port 0/0/0
 port 0/0/1
 port 0/0/2
 port 0/0/3
gatekeeper
 shutdown
telephony-service
 max-ephones 42
 max-dn 45
 ip source-address 10.20.10.10 port 2000
 auto assign 1 to 45
 number 301
 label 301
 name Reception
ephone  1
 no multicast-moh
 button  1:2
I have also attached design photo.
please help in configuring both CME to interconnect.
Rajan
Hi Eidy,
Pls configure the following on the respective gateways and let us know if this helps.
Office 1:
dial-peer voice 300 voip
destination-pattern 3..
session target ipv4:10.20.10.10
incoming called-number .
Office 2:
dial-peer voice 200 voip
destination-pattern 2..
session target ipv4:10.10.10.10
Rajan
Rajan
Hi Eidy,
Office 1:
Office 2:
Rajan
