Connection cisco ip 7911 picotando
eric.vieira
I would like some help from you. I have 50 cisco ip 7911 all managed by the call manager ... they are all functioned both for external connection to receive and internal connections via extension ... It happens that after 5 minutes of connections the connection starts to prick to the point of not having understood anything ... I disconnect and I call again I speak for another 5 minutes and starts again to prick there, I'm alone in this ... Can someone help me
Jaime Valencia
If you wish to post in Portuguese, I suggest you use the community dedicated to that language.
On the top grey bar, click the Language drop-down and you will find it there.
Otherwise, you'll have better luck if you use English here.
java
if this helps, please rate
Can someone help me
