06-08-2017 04:24 AM - edited 03-18-2019 12:15 PM
Someone could give me a little help with configuration about callmanager express versao 4.0,
I need that VG receives and sends calls to PSTN by extensions 1XX,but before that happens have to transform for these two numbers 222322090 e 222321990;please check the configuration below:
voice-port 0/3/0
cptone PT
connection plar 100
impedance complex2
voice-port 0/3/1
cptone PT
connection plar 100
impedance complex2
dial-peer voice 1 pots
destination-pattern 0.........
port 0/3/0
forward-digits 9
dial-peer voice 2 pots
preference 1
port 0/3/1
forward-digits 9
telephony-service
load 7960-7940 P00308000500
load 7941 term41.default.loads
load 7971 SCCP41.8-2-2SR2S.loads
max-ephones 40
max-dn 140
ip source-address XXXXXXX port 2000
system message XXXXXX
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1
number 100
label Recepcao
name Recepcao
06-08-2017 06:10 AM
Not exactly sure what you want to send as the other numbers, but you can use translation rules for that, the literature for translation rules configuration has plenty of usage examples you can use for reference.
06-08-2017 06:22 AM
Hi jaime,
I wanna send to PSTN these numbers 222322090 and 222321990,so I have to create a translation rule that transform all my extensions 1XX to these 222322090 and 222321990.
