connection plar command on FXO port don't forward the call to IP Phone
i have a voice gatway with FXO and the users can do out going calls normal , but when i put the connection plar opx  command  to forward the incoming calls on this port to an extension tha caller hear ringing but the Ip Phone don't ring and this the configuration on the router :
isdn switch-type basic-net3
voice-card 0
voice service voip
no supplementary-service h225-notify cid-update
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
license udi pid CISCO2911/K9 sn FTX1416AKDA
hw-module pvdm 0/0
interface BRI0/1/0
no ip address
isdn point-to-point-setup
interface BRI0/1/1
no ip address
interface BRI0/3/0
bandwidth 256
ip address X.X.X.X  255.255.255.0
encapsulation ppp
ip ospf network point-to-multipoint
ip ospf demand-circuit
dialer map ip X.X.X.X name main_cisco broadcast 27393602
dialer map ip X.X.X.X name main_cisco broadcast 27393627
dialer-group 1
no peer neighbor-route
ppp authentication chap
ppp multilink
ppp multilink load-threshold 1 either
no cdp enable
voice-port 0/1/0
compand-type a-law
connection plar 2228
voice-port 0/1/1
compand-type a-law
voice-port 0/2/0
supervisory disconnect dualtone mid-call
no vad
cptone EG
timeouts interdigit 5
timeouts call-disconnect 5
timeouts ringing 15
timeouts wait-release 5
connection plar opx 2228
impedance complex2
caller-id enable
voice-port 0/2/1
no vad
cptone EG
timeouts ringing 15
impedance complex2
caller-id enable
voice-port 0/2/2
no vad
cptone EG
timeouts ringing 15
impedance complex2
caller-id enable
voice-port 0/2/3
no vad
cptone EG
timeouts ringing 15
impedance complex2
caller-id enable
dial-peer voice 1000 voip
preference 1
destination-pattern [1-7]...
session target ipv4:X.X.X.X
voice-class codec 1
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
ip qos dscp cs5 signaling
no vad
dial-peer voice 1010 voip
preference 2
voice-class codec 1
no vad
dial-peer voice 1020 voip
preference 3
voice-class codec 1
no vad
dial-peer voice 1030 voip
preference 4
voice-class codec 1
no vad
dial-peer voice 1040 voip
preference 5
voice-class codec 1
no vad
dial-peer voice 1050 voip
preference 6
voice-class codec 1
no vad
dial-peer voice 1060 voip
preference 1
destination-pattern 9T
  voice-class codec 1
no vad
dial-peer voice 12 pots
preference 4
port 0/2/2
dial-peer voice 13 pots
preference 5
port 0/2/3
dial-peer voice 11 pots
preference 1
port 0/2/1
dial-peer voice 20 pots
preference 1
destination-pattern 11T
port 0/2/0
dial-peer voice 22 pots
preference 4
port 0/2/2
dial-peer voice 23 pots
preference 5
port 0/2/3
dial-peer voice 21 pots
preference 5
port 0/2/1
dial-peer voice 32 pots
destination-pattern 12T
port 0/2/2
dial-peer voice 33 pots
port 0/2/3
dial-peer voice 34 pots
port 0/2/1
dial-peer voice 35 pots
port 0/2/0
dial-peer voice 42 pots
preference 2
destination-pattern 13T
port 0/2/2
dial-peer voice 43 pots
preference 3
port 0/2/3
dial-peer voice 62 pots
destination-pattern 90[2-9]T
port 0/2/2
prefix 0
dial-peer voice 63 pots
port 0/2/3
prefix 0
dial-peer voice 65 pots
port 0/2/0
prefix 0
dial-peer voice 66 pots
port 0/2/1
prefix 0
dial-peer voice 52 pots
destination-pattern 901[^0126789]T
port 0/2/2
prefix 01
dial-peer voice 53 pots
port 0/2/3
prefix 01
dial-peer voice 54 pots
port 0/2/0
prefix 01
dial-peer voice 55 pots
preference 2
destination-pattern 901[0126789].......
port 0/2/2
prefix 01
dial-peer voice 73 pots
preference 3
port 0/2/3
prefix 01
dial-peer voice 74 pots
preference 2
port 0/2/0
prefix 01
dial-peer voice 75 pots
preference 2
port 0/2/1
prefix 01
gatekeeper
shutdown
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address X.X.X.X port 2000
max-ephones 42
max-dn 100
any one can help me please ????
8 Replies 8
raja Saravanan
To which port have you assigned the # 2228, please configure a dial-peer with destination--pattern #2228, pointing to the port to which 2228 is connected.
Apologies, i didnt notice that your request is to configure an IP phone as PLAR, I dont know whether you can configure an IP phone as PLAR or not, I dont have vast experience but till now, I haven't come across such a configuration ( IP phone for PLAR ).
Example;
dial-peer voice 100 pots
destination-pattern 2228
port 0/2/1
Shaggy
Message was edited by: raja Saravanan
Kindly know that the outgoing calls are working good, the
problem in conection plar command
the call dont go to the ip phone but the caller hear the ringing
and in the attachment you will find debug voice ccapi in out  output when o tried to call this port to frward it to 2228
What translation pattern are you using for 2228? Did you tried to test the PLAR internally are you able to reach the partition?
Are you sure that the CSS of the gateway has got the partiton to which 2228 is assigned.
Apologies, I hope i am taking you in a wrong direction, if the calling party hears the ring, then the call is answered,
please check the line by connecting a analog phone to the co-line and dial the # provided by the PSTN and check whether you are receiving the ring on the analog phone, there may be a chance that PSTN might have punched the CO line wrongly in the MDF, where you can make out bound calls but your incoming calls routing to a different site.
Thanks & Regards,
Shaggy
rapperjky
hi
why didnt see calling number
and
why dial-peer change each call.
tha call comming from PSTN .
I would lke to recall the concept of FxO port, when a call is made to your  home phone or any other analog CO line, the CO sends the ring and the calling party number, it does not send the called party number.
Will the calling party number be not displayed in the debug output? Am I correct?
Thanks & Regards,
Shaggy
Try to use this command to check which dial-peer it picks for the number 2228
#show dialplan 2228
Check what are all the dial peers are matching
Senthil
Message was edited by: SenthilKumar Sankar
dsobrinho
Level 9
Level 9
One question,
Connection plar from FXO to Recepcionist extension with CFW all configured to mobile number.
The call will be transfered to external mobile number?
Daniel Sobrinho
