Corporate Directory host not found
eran moyal
Hello ,
I have problem with cisco 7821,
sometimes when I open Corporate Directory   I got host not found error .
my version sip78xx.10-2-1-12.
any idea?
5 Replies 5
Deepak Rawat
Make sure that you are using the IP Address of CUCM server and not the Hostname in all the URL entries under
CUCM Administration >> System >> Enterprise Paramaters >> Phone URL Parameters
as it is quite possible, if you are using hostname there then sometimes the DNS resolution is not working causing the issue to happen
Deepak
- Rate Helpful Posts -
I used ip address of cucm.
Do you have another idea?
Is it happening only with 7821 phone models. If the answer is yes, then look at below defect and upgrade the phone firmware to 10.2(1.12):
https://tools.cisco.com/bugsearch/bug/CSCuq12291/?reffering_site=dumpcr
Deepak
my version of phones sip78xx.10-2-1-12 and I have still problem.
Yeah you did mention that in your original post. In that case, when the issue happens next time collect the Console Logs along with the Packet captures and open a TAC case so that further t/s can be done on this.
Deepak
