Corporate directory over IP Phone SSL VPN
KiloBravo
Having issues with corporate directory via a a phone using the IP Phone VPN Solution. We had issues with extension mobility and Corp directory at first, though a NAT statement resolved the extension mobility issue the corporate directory problem is sitll not working.
When selecting corporate directory it just comes up with a bunch of html, hitting 'update' makes no difference either.
I've tried an IP communicator over a anyconnect VPN usingthe same settings and the corporate direcotry works fine.
I've also put the  phone back on the inside network and it works fine.
Any ideas would be greatly appreicated.
KiloBravo
Issue resolved by manually inserting the alternate TFTP IP address on the phone.
