Corporate Phone Book error
gabiulici
I have to virtual machine 1 Pub and 1 Sub on 2 UCS servers.
I have cucm10.5 and when I pres the Corporate Phonephone on the device I receive the Connection failed. Any ideas.
23 Replies 23
Jaime Valencia
Make sure you're using IPs for the urls to avoid DNS issues, if you want to use hostnames, make sure your phones have a DNS configured.
java
if this helps, please rate
Pls check the attachment. The 7841 device worj fine, only the 6945 receive connection failed
HI.
Did you also configure secure url?
Do you have Restricted or Unrestricted version?
Let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
I have Unrestricted 10.5 after update from 8.6. On the 8.6 work fine
Do you have this issue on all phones type?
Does service url work?
Carlo
On all the 6945 device. On the 7841 device the corporate phone book works fine
Hi.
I had some issues too with  89XX and 69XX with CUCM unrestricted version when upgraded from 8.6 to 10.1.
I solved regenerating certificates callmanager.pem and tvs.pem from os administration --> security section.
Carlo
Hii,
I check under Serviceability and under Service Name in Pub and Sub the service CTL is not Start ( Deactivated). Maybe this is why I don't receive corporate contacts, my question is why on 7841 is working.
Any ideas??
Thanks for replay
Most probably is because they are using non secure url.
Cheers
Carlo
This is the message :
[12:12,15/12/14] Loads name : SCCP6945.9-4-1-3.loads
[12:12,15/12/14] Authenticating configuration file SEP442B031992E3.cnf.xml.sgn successfull
y
[12:12,15/12/14] SEP442B031992E3.cnf.xml.sgn (HTTP)
[12:12,15/12/14] ITL installed
[12:12,15/12/14] ITLSEP442B031992E3.tlv updated successfully
[12:12,15/12/14] ITLSEP442B031992E3.tlv (HTTP)
[12:12,15/12/14] ITLSEP442B031992E3.tlv updating
[12:12,15/12/14] CTLSEP442B031992E3.tlv not found in 10.217.196.4
[12:12,15/12/14] CTLSEP442B031992E3.tlv updating
[uptime: 0days,00:12:15] Loads name : SCCP6945.9-4-1-3.loads
[uptime: 0days,00:12:11] Authenticating configuration file SEP442B031992E3.cnf.xml.sgn su
ccessfully
Did you try to activate CTL service?
Carlo
No i don't activate the CTL service. You advise to on the service?
Hi.
I would try.
Because this phone type seems to need secure connection only with cucm.
Let me know
Carlo
Thanks for replay.
Strange because after update I have only problems. I will tray to activate the services to see what happen.
