CP-7861 MPP LOAD FAILING IMGAUTH_ERROR Verification Failure
MARK CASEY
I am trying to upload an MPP image.
The tftp server  has the content
SEPD42C44855D8E.cnf.xml
<device>
<loadInformation>sip78xx.11-0-1MPP-477</loadInformation>
</device>
And the contents of the File cp-78xx.11-0-1MPP-477.zip which includes
sip78xx.11-0-1MPP-477.loads.
the TFTP log shows the load of SEPD42C44855D8E.cnf.xml and sip78xx.11-0-1MPP-477.loads.
But the phone's log shows error below
I have used different load versions etc, but cant get the image to load
Any ideas what I am doing wrong
Thanks in Advance
Mark
7769 NOT Dec 02 14:34:33.073675 TFTPD-Requesting sip78xx.11-0-1MPP-477.loads from 10.242.10.1
7770 WRN Dec 02 14:34:33.074194 TFTPD-sendto() failed : Address family not supported by protocol
7771 NOT Dec 02 14:34:33.575278 TFTPD-Timeout: retransmit the last packet (1)
7772 NOT Dec 02 14:34:33.577658 TFTPD-Finished: rcvd 995 bytes
7773 NOT Dec 02 14:34:33.580802 dgetimage(16027)-FORCED-TFTP complete - status = 0
7774 NOT Dec 02 14:34:33.585777 dgetimage(16027)-GETIMG AUTH RAM FILE
7775 ERR Dec 02 14:34:33.586265 dgetimage(16027)-sec_validate_image_file
7776 ERR Dec 02 14:34:33.586723 dgetimage(16027)-sec_validate_image_file Cisco header size (340)
7777 ERR Dec 02 14:34:33.592369 dgetimage(16027)-IMGAUTH_ERROR Verification Failure
7778 NOT Dec 02 14:34:33.592980 dgetimage(16027)-astat = -12, realfname=sip78xx.11-0-1MPP-477.loads, buf->offset=0
7779 NOT Dec 02 14:34:33.593437 dgetimage(16027)-GETIMG-DEBUG auth astat:[-12], VFY_SUCCESS:0
7780 NOT Dec 02 14:34:33.593865 dgetimage(16027)-GETIMG: astat: -12, buf->status:244, VFY_SUCCESS:0
7781 NOT Dec 02 14:34:33.594445 dgetimage(16027)-GETIMG: returned with 244
7782 NOT Dec 02 14:34:33.595482 img-pfs-&&&done dd_get_image_ replies 244
7783 ERR Dec 02 14:34:33.595635 img-pfs-LOAD6 [offset:-244] downdload image file failure.
7784 NOT Dec 02 14:34:33.622920 dgetimage(16027)-DDGETIMG.RESULT [Error description unknown]
7785 NOT Dec 02 14:34:33.628108 downd-SOCKET accept errno=4 "Interrupted system call"
MARK CASEY
Hi All
I have now worked out the question I should have asked.
With the old 7900 series phone, I could move from SIP to SCCP loads
Can I change a CP-7861-K9 standard image phone to a MPP multiplatform image ?
If so how ?
mark
