CP-7911G Wall Plate Mount
blackmichael
I am trying to mount a 7911 phone to the wall using a standard wall plat.  Apparently the holes do not line up.  Does anyone know of a wall plate in which the 7911 can mount flat on the wall?
The Cisco locking wall bracket is not good for my application and since it tilts the phone up.
Rob Huffman
Hi Michael,
The spacing of the Back-side mounting holes enables direct mounting
to the Electrical box, no Mounting plate is required
Cheers!
Rob
Is there a specific screws to use for the best fist?
Also is there a plate i can use to mount the RJ45 port behind the phone so its not an empty electrical box.
Hi Michael,
The mounting holes are pretty forgiving and will work with
a number of Screws. We found the "best" fit was to use
a 1mm x 1mm (round head Phillips)
I have not seen a Mounting plate that would work within an
electrical box We are an "Amp" cabling infrastructure
shop, so a Part# like the following worked well within the
box ;
http://www.ampnetconnect.com/product_cut_sheet.asp?pn=137519100
Cheers!
Rob
