CP-7912G on BE6000
francisco-amaya
The IP Phone CP-7912G is support on BE6000?
Jaime Valencia
Yes, you can configure it.
java
if this helps, please rate
Karthik Sivaram
Level 4
Level 4
You have not mentioned the ver of CUCM  .   I am attaching the 9.1.1 doc and yes it supports 7912
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_1_1/ccmsys/CUCM_BK_C5565591_00_cucm-system-guide-91_chapter_0101011.html
Hope this helps!
Karthik Sivaram
