04-03-2013 04:09 AM - edited 03-16-2019 04:34 PM
Can anyone help about the CP-8831 IP Conference Phone?
I want to know whether the Wired and wireless Microphone can be used simultaneously on the Base conference phone.
Also, can there be more that two wireless microphones when it is configured for daisy chain?
Peter,.
Solved! Go to Solution.
04-03-2013 05:44 AM
it can support only 2 wired min and 2 wireless mic. kindly find the below link
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps12965/data_sheet_c78-726887.pdf
Anas
please don't forget to rate the helpful posts
04-03-2013 05:44 AM
Anas
04-05-2013 01:09 PM
Actually it can only support one of both; it is either/or. If you connect both wired and wireless, then the system will prioritize wireless MICs and disable the wired MICs.
