CP-88XX photo size not fit
Chi Fai Leung
I have to take a mass photo to push as the CP-88XX phones as the background image, but I set the photo size according to the CP-88XX datasheet, but I discovered the size is not correct.
Finally, I got the photo not fit the size into the phone. Do u meet the same problem?
Jaime Valencia
Have you looked at this bug?
Documentation: background image size/path for 88xx phones is 800x480x24
CSCus27001
java
if this helps, please rate
