IP Telephony and Phones
Labels
Hi, i have this messages,%SCHED-2-EDISMSCRIT: Critical/high priority process MS_AC Dsprm Main may not dismiss. -Process= "MS_AC Dsprm Main", ipl= 0, pid= 44 -Traceback= 0x60A51F90 0x617C3BB0 0x60A40534 0x60A663B0 0x60A63FF8 0x60A658B8 0x604AD7F8 0x60...
Hi All,We have CUCM 10.5 with SIP Trunks to Gateways. Every time the gateways reload we need to manually reset the SIP Trunk from the CUCM. Calls won't work until the SIP Trunk is reset. I don't believe this is normal. Is there a way that we can reso...
Hi Guys,One area in CUCM I have not touched is using SQL.Could you please suggest documents or books that I should go through to be able to generate my own set of SQL commands for taking out information from CUCM CLI.Or is there any predefined List o...
amansin74 by Level 1
  • 13489 Views
  • 9 replies
Hi all,How is it possible to block  some  staff,  forwarding their phonesets to another destination?But  blocking the forwarding feature of this staff, should not inhibit this staff to call anybody, or transfer call to anybody.What is the solution fo...
Hi,I'm installing some used 7906 phones for some simple single line needs.  I've got something interesting going on though - the phones boot up and register fine but then launch the services screen.  If I press exit, or press the services button to g...
warben61 by Level 1
  • 3142 Views
  • 5 replies
Hello everybody Does somebody know how to make a line button wich opens a URL on a CP7975G? So I've got an Cisco 7975G IP-Phone wich runs on SIP-firmware Vers. 8-4.1, The phone runs on a 3rd Party SIP-Server so I had to config the phone with a SEP{MA...
