CP 9971 background default wallpaer
Vinod.s
Level 3
Level 3
Hi all,
I have uploaded background image for cp 9971 and we have uploaded xml file also.
Now user has to select manually application>>Background image>>select image.
Is there option we automatically set this wallpaper on all phone without manual intervention.
Thanks in advance.
2 Accepted Solutions
You can do that by Using Common Phone profile .
  1. Upload images to CUCM TFTP(Folder based on the phone model)
  2. Enable End User Access to Phone Background Image Setting” should be unchecked on common phone profile
  3. Add the file name on Background IMage
  4. Apply the profile on phone and apply  config
Response Signature
Hello Nithin,
Just now checked, It works for 9971 also.
Response Signature
Hello Nithin,
Is this step is applicable for 9971 for also ? i did this for DX650 .
Its applicable for 9971 too. But i never tried with 9971, i have tested this with 79XX,88XX.
Response Signature
Hello Nithin,
