CP7841 registration problem
mvh4205
Bit of a newbie question. We’re trying to set-up 2 CP.7841 phones with the Call Manager on a Cisco 4431 router. The phones are not registering on the router.  The router version is 16.9. The phone’s original firmware version was SIP78xx.12-0-1-11. We tried upgrading the phones to SIP78xx.12-8-1-0001-455. The problem is the same with both firmware versions.
Have cut & pasted the config file being applied to the router and also TFTP and VOIP debug. Attached is a Wireshark file CSV file captured using the Router Web interface->Trouble Shooting->Packet Capture facility. The phones are set with static IP addresses (192.168.90.162 & 192.168.90.164). The phones also have the TFTP server address set to 192.168.90.6.
    The wireshark file shows that the phones request config files from the router, (eg:- TEST4.csv lines 33 to 66), the default config of XMLDefault.cnf.xml being transferred to the phones seemingly successfully. The phones then request registration with the router which is refused with a 404 error. (eg:- TEST4.csv lines 128 to 131).  Any help would be appreciated.
configure terminal
version 16.9
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname TESTVOIP2
logging console warnings
ip http authentication local
no service config
no cdp run
voice-card 0/4
! router web interface
interface GigabitEthernet0
 no shutdown
!  port connecting to phones
interface GigabitEthernet0/0/1
 description TEST LAN 1
 ip address 192.168.90.6 255.255.255.0
 ip pim sparse-dense-mode
 media-type rj45
 no snmp trap link-status
 no shutdown
 no cdp enable
ip tftp source-interface GigabitEthernet0/0/1
ip http server
no ip http secure-server
ip pim rp-address 192.168.90.6
sip
 registrar ipv4:192.168.90.6
voice service voip
 sip
 registrar server
! Setup VOIP telephony
voice service voip
 allow-connections sip to sip
voice register global
 mode cme
 source-address 192.168.90.6 port 5060
 max-dn 50
 max-pool 10
voice register dn 1
 number 101
 name test1
 label test1
voice register dn 2
 number 102
 name test2
 label test2
voice register dn 3
 number 201
 name test3
 label test3
voice register dn 4
 number 202
 name test4
 label test4
voice register pool 1
 type 7841
 id mac 3C41.0E4B.84BB
 number 1 dn 1
 number 2 dn 2
voice register pool 2
 type 7841
 id mac 3C41.0E4B.839C
 number 1 dn 3
 number 2 dn 4
 create profile
end
*Sep  4 10:38:59.484: TFTP: Finished system:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 379
*Sep  4 10:39:01.793: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:01.803: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:01.813: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:01.824: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:01.834: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.065: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.075: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.086: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.097: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
 --More--         *Sep  4 10:39:02.107: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.131: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.132: voice_reg_get_reg_expires_timer: no voice register pool found
*Sep  4 10:39:02.132: VOICE_REG_POOL: Register request for (AUTO-REG) from (192.168.90.162)
*Sep  4 10:39:02.132: VOICE_REG_POOL: Auto Registration request from Name:3c410e4b84bb IP:192.168.90.162
*Sep  4 10:39:02.132: VOICE_REG_POOL: Auto-register: pool already present for mac: 3c410e4b84bb
*Sep  4 10:39:02.132: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.132: voice_reg_get_phone_index_from_contact: No contact list
*Sep  4 10:39:02.395: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.396: voice_reg_get_reg_expires_timer: no voice register pool found
*Sep  4 10:39:02.396: VOICE_REG_POOL: Register request for (AUTO-REG) from (192.168.90.164)
*Sep  4 10:39:02.396: VOICE_REG_POOL: Auto Registration request from Name:3c410e4b839c IP:192.168.90.164
 --More--         *Sep  4 10:39:02.396: VOICE_REG_POOL: Auto-register: pool already present for mac: 3c410e4b839c
*Sep  4 10:39:02.396: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.396: voice_reg_get_phone_index_from_contact: No contact list
*Sep  4 10:39:02.730: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.741: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.746: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.748: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.752: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.756: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.759: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.772: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.977: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
 --More--         *Sep  4 10:39:02.988: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.993: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:02.996: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:03.000: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:03.003: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:03.006: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:03.017: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:03.269: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:03.279: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:03.289: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:03.496: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
*Sep  4 10:39:03.511: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
 --More--         *Sep  4 10:39:03.537: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
We've now managed to fix the problem. What seemed to fix it was getting the router to generate the SEP<mac>.cnf.xml files for each phone. This required a rather strange repeat of the Voice Register Pools (for each of the 4 phones) and Create Profile commands. To be be honest, it looks like a bug in the Cisco firmware to me. Once our service contract has come through, we'll upgrade to the latest Cisco Router firmware and see if anything changes for the better. A fragment of our current router config is below :-
sip
voice service voip
sip
registrar server
voice service voip
mode cme
max-dn 50
max-pool 10
voice register dn 1
number 101
name test1
label test1
voice register dn 2
number 102
name test2
label test2
voice register dn 3
number 201
name test3
label test3
voice register dn 4
number 202
name test4
label test4
voice register dn 5
number 301
name test5
label test5
voice register dn 6
number 302
name test6
label test6
voice register dn 7
number 401
name test7
label test7
voice register dn 8
number 402
name test8
label test8
type 7841
number 1 dn 1
number 2 dn 2
type 7841
number 1 dn 3
number 2 dn 4
voice register pool 3
type 7841
id mac 3C41.0E4B.84CB
number 1 dn 5
number 2 dn 6
voice register pool 4
type 7841
id mac 3C41.0E4B.846B
number 1 dn 7
number 2 dn 8
load 7841 sip78xx.12-8-1-0001-455
tftp-path flash:
file text
no create profile
create profile
end
configure terminal
type 7841
number 1 dn 1
number 2 dn 2
type 7841
number 1 dn 3
number 2 dn 4
type 7841
number 1 dn 5
number 2 dn 6
type 7841
number 1 dn 7
number 2 dn 8
tftp-path flash:
file text
no create profile
create profile
tftp-server flash:SEP3C410E4B839C.cnf.xml
tftp-server flash:SEP3C410E4B84BB.cnf.xml
tftp-server flash:SEP3C410E4B84CB.cnf.xml
tftp-server flash:SEP3C410E4B846B.cnf.xml
remove the below.
sip
Try the below.
voice service voip
sip
registrar server expires max 600 min 60
mode cme
source-address X.X.X.X port 5060
max-dn 100
max-pool 50
load 7821 sip78xx.12-6-1-0101-692
load 7832 sip7832.12-5-1SR3-74
load 7841 sip78xx.12-6-1-0101-692
timezone 34
date-format D/M/Y
tftp-path flash:
last
no create profile
Create Profile
Response Signature
We've tried what you suggested, but unfortunately it hasn't made any difference. The interaction between the phones and the router is unchanged, culminating in registration refusal.
sip
voice service voip
sip
registrar server
voice service voip
mode cme
max-dn 50
max-pool 10
voice register dn 1
number 101
name test1
label test1
voice register dn 2
number 102
name test2
label test2
voice register dn 3
number 201
name test3
label test3
voice register dn 4
number 202
name test4
label test4
voice register dn 5
number 301
name test5
label test5
voice register dn 6
number 302
name test6
label test6
voice register dn 7
number 401
name test7
label test7
voice register dn 8
number 402
name test8
label test8
type 7841
number 1 dn 1
number 2 dn 2
type 7841
number 1 dn 3
number 2 dn 4
type 7841
number 1 dn 5
number 2 dn 6
type 7841
number 1 dn 7
number 2 dn 8
tftp-path flash:
file text
no create profile
create profile
end
configure terminal
type 7841
number 1 dn 1
number 2 dn 2
type 7841
number 1 dn 3
number 2 dn 4
type 7841
number 1 dn 5
number 2 dn 6
type 7841
number 1 dn 7
number 2 dn 8
tftp-path flash:
file text
no create profile
create profile
