Create and send email on UCCX/IP-IVR 8.5 script with Exchange 365
jocisner
Level 4
Level 4
I am running Contact Center Express 8.5.1.11002-22 and I have a script where I want to add a step where I will create and send a document.  This has usually worked well with normal exchange.  Now I have a customer that is using Exchange 365 in the clound and I was wondering if anyone has had any success getting this to work?
Jonathan Schulenberg
If you're keeping an on-prem Hub Transport server for unauthenticated relay (many customers do since a lot of apps rely on this) you can just point CCX to that. If not you would need to do authenticated SMTP.
Please remember to rate helpful responses and identify helpful or correct answers.
Thanks Jonathan thats exactly what I needed to know.
