Disconnect cause = 28
ElwinMkanyika
Hi Guys!
Please help me solve this issue.
This is the network Topology:
HQ -> Branch -> smaller office
1) IP Calls to both branch and Smaller Office work fine
2) IP Calls from both Branch and smaller office to HQ and other branches also work fine
3) The Problem is that a call from the branch to the smaller office does not go through. When I do a
debug voice ccapi inout I see that the disconnect cause is 28. I have also noted that the destination field is empty.
This is the debug for a successful call from Branch A 105 to Brach B 111
Apr 17 17:36:04.954 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x2BDABA7C, callID=0x10C4, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x2BDABA7C, Call Id=4292
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
Apr 17 17:36:06.886 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_begin:
   Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
   Source Call Id=4292, Digit=7, DigitBeginFlags=0x0,
   Rtp Timestamp=0x193AFC0, Rtp Expiration=0x0
Apr 17 17:36:06.886 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_end:
   Source Call Id=4292, Digit=7, Duration=100,
   Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
   Call Entry(Handoff Depth=0)
Apr 17 17:36:07.514 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_begin:
   Source Call Id=4292, Digit=0, DigitBeginFlags=0x0,
   Rtp Timestamp=0x1942CC0, Rtp Expiration=0x0
Apr 17 17:36:07.514 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_end:
   Source Call Id=4292, Digit=0, Duration=100,
Apr 17 17:36:08.562 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_begin:
   Source Call Id=4292, Digit=4, DigitBeginFlags=0x0,
   Rtp Timestamp=0x194A9C0, Rtp Expiration=0x0
Apr 17 17:36:08.562 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_end:
   Source Call Id=4292, Digit=4, Duration=100,
Apr 17 17:36:09.194 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_begin:
   Source Call Id=4292, Digit=6, DigitBeginFlags=0x0,
   Rtp Timestamp=0x19526C0, Rtp Expiration=0x0
Apr 17 17:36:09.194 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_end:
   Source Call Id=4292, Digit=6, Duration=100,
Apr 17 17:36:10.170 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_begin:
   Source Call Id=4292, Digit=1, DigitBeginFlags=0x0,
   Rtp Timestamp=0x195A3C0, Rtp Expiration=0x0
Apr 17 17:36:10.170 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_end:
   Source Call Id=4292, Digit=1, Duration=100,
Apr 17 17:36:10.426 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x19620C0, Rtp Expiration=0x0
Apr 17 17:36:10.426 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_end:
Apr 17 17:36:10.670 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x1969DC0, Rtp Expiration=0x0
Apr 17 17:36:10.670 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_end:
Apr 17 17:36:11.562 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_begin:
   Rtp Timestamp=0x1971AC0, Rtp Expiration=0x0
Apr 17 17:36:11.562 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_digit_end:
Apr 17 17:36:21.562 MSK: //4292/96319BF8A4EB/CCAPI/cc_handle_inter_digit_timer:
   Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
Apr 17 17:36:21.562 MSK: //4292/96319BF8A4EB/CCAPI/ccCallReportDigits:
   (callID=0x10C4, digit_event=0x0, enable=FALSE, consume=FALSE)
   Enabled=TRUE, Call Id=4292
Apr 17 17:36:21.562 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x2BDABA7C, callID=0x10C4, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Apr 17 17:36:21.562 MSK: //4292/96319BF8A4EB/CCAPI/ccCallDisconnect:
   Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28)
Apr 17 17:36:21.562 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Apr 17 17:36:33.898 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2BDABA7C, Tag=0x0, Call Id=4292,
   Call Entry(Disconnect Cause=28, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Apr 17 17:36:33.898 MSK: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 17 17:36:33.898 MSK: :cc_free_feature_vsa freeing 2BFE3270
Apr 17 17:36:33.898 MSK:  vsacount in free is 0
Apr 17 17:36:41.126 MSK: //-1/0080DFD48100/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Support
   ----- ccCallInfo IE subfields -----
   cisco-ani=701000105
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=1#704600111
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Apr 17 17:36:41.126 MSK: //-1/0080DFD48100/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x30FB8CA8, Call Info(
   Calling Number=701000105,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1#704600111(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=2000, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=4293
Apr 17 17:36:41.126 MSK: //-1/0080DFD48100/CCAPI/ccCheckClipClir:
   In: Calling Number=701000105(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=701000105(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Apr 17 17:36:41.126 MSK: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 17 17:36:41.126 MSK: :cc_get_feature_vsa malloc success
Apr 17 17:36:41.126 MSK:  cc_get_feature_vsa count is 1
Apr 17 17:36:41.126 MSK: :FEATURE_VSA attributes are: feature_name:0,feature_time:738079352,feature_id:4511
Apr 17 17:36:41.126 MSK: //4293/0080DFD48100/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=701000105(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=1#704600111(TON=Unknown, NPI=Unknown))
Apr 17 17:36:41.130 MSK: //4293/0080DFD48100/CCAPI/cc_process_call_setup_ind:
   Event=0x2B596318
Apr 17 17:36:41.130 MSK: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 1#704600111
Apr 17 17:36:41.130 MSK: //4293/0080DFD48100/CCAPI/ccCallSetContext:
   Context=0x2BFEB9A4
   >>>>CCAPI handed cid 4293 with tag 2000 to app "_ManagedAppProcess_Default"
Apr 17 17:36:41.130 MSK: //4293/0080DFD48100/CCAPI/ccCallProceeding:
Apr 17 17:36:41.130 MSK: //4293/0080DFD48100/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=20002, Params=0x2BFEA5DC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Apr 17 17:36:41.130 MSK: //4293/0080DFD48100/CCAPI/ccCheckClipClir:
   Destination Pattern=111$, Called Number=111, Digit Strip=TRUE
   Called Number=111(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=Support
   Account Number=Support, Final Destination Flag=TRUE,
   Guid=0080DFD4-69A5-E116-8100-C7010A0A0A2E, Outgoing Dial-peer=20002
This is an unsuccessful call from Branch B to smaller office C 110
Apr 17 17:36:04.526 MSK: //4291/007BEC907F00/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Apr 17 17:36:04.526 MSK: //4291/007BEC907F00/CCAPI/cc_api_get_transfer_info:
Apr 17 17:36:04.526 MSK: //4290/007BEC907F00/CCAPI/cc_api_get_transfer_info:
Apr 17 17:36:04.530 MSK: //4291/007BEC907F00/CCAPI/cc_api_call_feature:
   Feature Type=6, Interface=0x2BDABA7C, Call Id=4291
Apr 17 17:36:04.530 MSK: //4291/007BEC907F00/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2BDABA7C, Tag=0x0, Call Id=4291,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Apr 17 17:36:04.530 MSK: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 17 17:36:04.530 MSK: :cc_free_feature_vsa freeing 2BFE35F0
Apr 17 17:36:04.530 MSK:  vsacount in free is 1
Apr 17 17:36:04.542 MSK: //4290/007BEC907F00/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30FB8CA8, Tag=0x0, Call Id=4290,
Apr 17 17:36:04.542 MSK: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 17 17:36:04.542 MSK: :cc_free_feature_vsa freeing 2BFE3270
Apr 17 17:36:04.542 MSK:  vsacount in free is 0
Apr 17 17:36:04.954 MSK: //-1/96319BF8A4EB/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=111
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
Apr 17 17:36:04.954 MSK: //-1/96319BF8A4EB/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2BDABA7C, Call Info(
   Calling Number=111,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20002, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Apr 17 17:36:04.954 MSK: //-1/96319BF8A4EB/CCAPI/ccCheckClipClir:
   In: Calling Number=111(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=111(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Apr 17 17:36:04.954 MSK: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 17 17:36:04.954 MSK: :cc_get_feature_vsa malloc success
Apr 17 17:36:04.954 MSK:  cc_get_feature_vsa count is 1
Apr 17 17:36:04.954 MSK: :FEATURE_VSA attributes are: feature_name:0,feature_time:738079352,feature_id:4510
Apr 17 17:36:04.954 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=111(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown))
Apr 17 17:36:04.954 MSK: //4292/96319BF8A4EB/CCAPI/cc_process_call_setup_ind:
   Event=0x2B596318
Apr 17 17:36:04.954 MSK: //4292/96319BF8A4EB/CCAPI/ccCallSetContext:
   Context=0x2BFF5A64
   >>>>CCAPI handed cid 4292 with tag 20002 to app "_ManagedAppProcess_Default"
Apr 17 17:36:04.954 MSK: //4292/96319BF8A4EB/CCAPI/ccCallSetupAck:
   Call Id=4292
Apr 17 17:36:04.954 MSK: //4292/96319BF8A4EB/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
Apr 17 17:36:04.954 MSK: //4292/96319BF8A4EB/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=4292
Apr 17 17:36:04.954 MSK: //4292/96319BF8A4EB/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Apr 17 17:36:04.954 MSK: //4292/96319BF8A4EB/CCAPI/ccCallReportDigits:
   (callID=0x10C4, digit_event=0x1, enable=TRUE, consume=FALSE)
Apr 17 17:36:05.902 MSK: DHCPD: Sending notification of ASSIGNMENT:
Apr 17 17:36:05.902 MSK:  DHCPD: address 10.46.222.12 mask 255.255.255.0
Apr 17 17:36:05.902 MSK:   DHCPD: htype 1 chaddr 9caf.cafe.ae8f
Apr 17 17:36:05.902 MSK:   DHCPD: lease time remaining (secs) = 2592000
Apr 17 17:36:09.902 MSK: DHCPD: Sending notification of ASSIGNMENT:
Apr 17 17:36:09.902 MSK:  DHCPD: address 10.46.222.12 mask 255.255.255.0
Apr 17 17:36:09.902 MSK:   DHCPD: htype 1 chaddr 9caf.cafe.ae8f
Apr 17 17:36:09.902 MSK:   DHCPD: lease time remaining (secs) = 2592000
Apr 17 17:36:09.942 MSK: DHCPD: Sending notification of ASSIGNMENT:
Apr 17 17:36:09.942 MSK:  DHCPD: address 10.46.222.12 mask 255.255.255.0
Apr 17 17:36:09.942 MSK:   DHCPD: htype 1 chaddr 9caf.cafe.ae8f
Apr 17 17:36:09.942 MSK:   DHCPD: lease time remaining (secs) = 2592000
Am guessing the issue is that the call from 111 to 110 does not work because:
1) The destination number in the debug is empty
2) The source number shows 111 instead of appending 704600 to 111
Kindly help in coming up with a solution to this problem.
Faith
0 Replies 0
