02-07-2018 07:20 PM - edited 03-17-2019 12:08 PM
I need to find the Created/Last Accessed: date for all the mailboxes in CUE so that the least used mailboxes can be deleted .So that we are in compliance with licensing requirements.
Currently I am able to get the required information for individul mailboxes
cue# show voicemail detail mailbox "XXXXX"
Owner: /sw/local/users/XXXXXXX
Type: Personal
Description: XXXXXXX mailbox
Announcement Only: No
Busy state: idle
Enabled: true
Allow login without pin: no
Mailbox Size (seconds): 2880
Message Size (seconds): 240
Play Tutorial: false
Fax Enabled: true
Space Used (seconds): 0
Total Message Count: 0
New Message Count: 0
Saved Message Count: 0
Future Message Count: 0
Deleted Message Count: 0
Fax Message Count: 0
Expiration (days): 30
Created/Last Accessed: Feb 05 2018 13:42:40 EST
Current Active Greeting: standard
Is there a way I can get the required information for all the mailboxes from CLI at once ?
Solved! Go to Solution.
02-08-2018 06:14 AM
Hi there,
I would try this command;
show voicemail mailboxes idle X
Where X = the number of idle days. So maybe something like 60 or 90 days.
Cheers!
Rob
02-08-2018 06:14 AM
Hi there,
Cheers!
Rob
