CUBE and SRST licenses
wfjones
I recently installed a UC License on a 3945 that wasn't installed prior. That is fine, however on our CPE list I saw where they, (the customer), needs the following Licenses:
FL-SRST
FL-CME-SRST-100
FL-CME-SRST-25
FL-CUBEE-25
Do each of these licenses require a PAK ID and need to be downloaded from CCO and installed on flash? I am assuming yes, but I haven't had to do this before.
The UC license  SL-39-UC-K9 is on the router and good to go.
Rajan
You could refer the below discussion:
https://supportforums.cisco.com/discussion/12415291/cube-license
shenbagarajan
