CUBE - ATT IP FLex
dennis.maston1
I am working with my partner and ATT setting up a 2921 for IP FLex. The system is working fine currently with a PRI but we are looking to migrate the site to IP FLex.
CUCM seems to be setup ok, the CUBE elements seem to be setup ok - however I cannot bind the interface on the Dial Peers.
At this time when calls come in, the end point rings and everything looks good on the debug logs, however when you try to answer nothing happens, the 2nd time you hit answer the call disconnects.  Debug Below:
477859: May 10 16:09:51.867: //629155/76192ACF9D48/CCAPI/cc_api_call_alert:
   Interface=0x29662448, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
477860: May 10 16:09:51.867: //629155/76192ACF9D48/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
477861: May 10 16:09:51.867: //629154/76192ACF9D48/CCAPI/ccCallAlert:
477862: May 10 16:09:51.867: //629154/76192ACF9D48/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
477863: May 10 16:09:53.319: //629155/76192ACF9D48/CCAPI/cc_api_call_disconnected:
   Cause Value=63, Interface=0x29662448, Call Id=629155
477864: May 10 16:09:53.319: //629155/76192ACF9D48/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=63, Retry Count=0)
477865: May 10 16:09:53.319: //629154/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
477866: May 10 16:09:53.319: //629155/76192ACF9D48/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=629155
477867: May 10 16:09:53.319: //629155/76192ACF9D48/CCAPI/ccCallDisconnect:
   Cause Value=63, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=63)
477868: May 10 16:09:53.319: //629155/76192ACF9D48/CCAPI/ccCallDisconnect:
   Cause Value=63, Call Entry(Responsed=TRUE, Cause Value=63)
477869: May 10 16:09:53.323: //629155/76192ACF9D48/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29662448, Tag=0x0, Call Id=629155,
   Call Entry(Disconnect Cause=63, Voice Class Cause Code=0, Retry Count=0)
When the call comes in it hits first DP, then the incoming DP.
 Incoming Dial-peer=1500, Progress Indication=NULL(0), Calling IE Present=TRUE,
477842: May 10 16:09:51.859: //629154/76192ACF9D48/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=601, Params=0x301ADE74, Progress Indication=NULL(0)
477843: May 10 16:09:51.859: //629154/76192ACF9D48/CCAPI/ccCheckClipClir:
   In: Calling Number=XXXXXXXXXX (TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
I am binded on my interface, however that option doesn't exist on the Dial Peers..    Some configs below:
voice service voip
 address-hiding
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol none
 h323
 sip
  bind control source-interface Loopback2
  bind media source-interface GigabitEthernet0/1.2      ( i have tried binding both to Loop2 and 0/1.2)
  header-passing error-passthru
  no update-callerid
  midcall-signaling passthru
  privacy-policy passthru
  g729 annexb-all
  sip-profiles 15
voice class uri 1000 sip
 host 1xx.xx.xx.181
voice class uri 2000 sip
 host 10.xx.xx.10
voice class codec 1
 codec preference 1 g729r8
 codec preference 2 g711ulaw
voice class sip-profiles 1
 request INVITE sip-header Diversion modify "<sip:(.*)@(.*)>" "<sip:xxxxx\1@\2>"
 request REINVITE sdp-header Attribute modify "a=T38FaxFillBitRemoval:0" ""
voice class sip-profiles 15
 request INVITE sip-header Allow-Header modify ", UPDATE" ""
 request REINVITE sip-header Allow-Header modify ", UPDATE" ""
 response 180 sip-header Allow-Header modify ", UPDATE" ""
 response 200 sip-header Allow-Header modify ", UPDATE" ""
voice translation-rule 1
 rule 1 // /A/
voice translation-rule 3
 rule 1 /^A/ //
voice translation-profile outbound-strip-A
 translate called 3
voice translation-profile inbound-from-carrier
 translate called 1
interface Loopback2
 ip address xx.xx.xx.194 255.255.255.255
interface GigabitEthernet0/0
 description ATT_Circuit_ID_MLEC.XXXXX..ATI
 no ip address
 duplex auto
 speed 100
interface GigabitEthernet0/0.50
 bandwidth 5000
 encapsulation dot1Q 50
 ip address xx.xx.xx.xx 255.255.255.252
 service-policy output TRAFFIC_SHAPING
 no ip address
 duplex auto
 speed 1000
interface GigabitEthernet0/1.1
 encapsulation dot1Q 1 native
 ip address 10.xx.xx.4 255.255.224.0
 vrrp 1 ip 10.xx.xx.1
 vrrp 1 preempt delay minimum 20
 vrrp 1 priority 110
 vrrp 1 track 1 decrement 90
mgcp bind control source-interface GigabitEthernet0/1.2
mgcp bind media source-interface GigabitEthernet0/1.2
sccp local GigabitEthernet0/1.2
sccp ccm 10.xx.xx.1 identifier 1 version 7.0
sccp ccm 10.xx.xx.10 identifier 100 version 7.0
sccp
sccp ccm group 1
 associate ccm 100 priority 1
 associate profile 2 register mtp0123456789ab
 associate profile 1 register confprofile1
dspfarm profile 2 transcode
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729r8
 codec g729br8
 maximum sessions 2
 associate application SCCP
dspfarm profile 1 conference
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729r8
 codec g729br8
 maximum sessions 4
 conference-join custom-cptone jointone
 conference-leave custom-cptone leavetone
dial-peer voice 601 voip
 description Inbound to CUCM
 translation-profile outgoing outbound-strip-A
 preference 1
 destination-pattern A.T
 session protocol sipv2
 session target ipv4:10.xx.xx.10
 session transport udp
 voice-class sip url sip
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 1500 voip
 description Inbound Call from ATT to CUBE
 translation-profile incoming inbound-from-carrier
 incoming called-number .T
 voice-class codec 1
 voice-class sip asymmetric payload full
 voice-class sip asserted-id pai
 voice-class sip privacy-policy passthru
 voice-class sip profiles 1
 dtmf-relay rtp-nte
 fax-relay sg3-to-g3
 fax rate 14400
 no vad
dial-peer hunt 1
sip-ua
 no remote-party-id
 retry invite 2
telephony-service
 bulk-speed-dial list 0 flash:test.txt
 max-conferences 8 gain -6
 transfer-system full-consult
I tried but was unable to add this to the DPs
voice-class sip bind control source interface gig0/1.2
voice-class sip bind media source interface gig0/1.2
Any assistance is appreciated, it's my first time seeing IPFlex.
Thanks to all.
-Dennis
We can see CUCM is sending  503 with cause 47 to the CUBE, it looks to be codec issue to me and you might not have transcoder assigned to the MRGL of the trunk.
I can see service provider is sending g729.Can you force same codec on the dial-peer going to CUCM ?
480260: May 10 19:14:24.410: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 503 Service Unavailable
Reason: Q.850;cause=47
Date: Tue, 10 May 2016 18:01:30 GMT
From: "XXXXX " <sip:1010100101@xx.xx.xx.194>;tag=DB5B5F64-A10
Allow-Events: presence
Content-Length: 0
To: <sip:8505642088@10.xx.xx.10>;tag=0796d93b-b901-4828-9c35-5c1df51b06d6-23234267
Call-ID: 3CB43817-161A11E6-9F02AF8A-EDB429F4@xx.xx.xx.194
Via: SIP/2.0/UDP xx.xx.xx..194:5060;branch=z9hG4bKAF197D
CSeq: 101 INVITE
Deepak Mehta
Can you enable  debug ccsip messages and debug ccsip all and paste the output.
Make sure that SIP trunk is running on all nodes and destination ip address is correct.
Also transcoder profile have to be assigned to trunk,phone MRGL , in case there is need for transcoder or MTP.thanks
I have attached a debug file.
Thank you Deepak.
Received:
Content-Length: 0
CSeq: 101 INVITE
Thank you Deepak,  We are able to get the calls to connect now.
We have a new issue of 1 way voice that we are looking into, but the calls at least making it in and connecting.
