CUBE Call Re-direct
msasala
This weekend we are upgrading our CUCM, UCONN, and UCCX. I would like to have our Main Line forwarded back out to the PSTN to another number via our CUBE Router. Does any one have a sample config of how this can be done?
R0g22
You can ask your ITSP to setup a call forward for your DID without the need to add additional config on the CUBE.
It is possible on the cube as well, all you have to do is a create specific dial peer for the dnis and the cube will route the call but does your itsp allow hair pinning like this ? They might reject the hairpinned call straight up seeing it as a toll fraud.
