01-22-2018 02:46 AM - edited 03-17-2019 12:00 PM
Dear all,
I am currently setting up a CUBE (ISR 4321) in order to connect to the ISP's SIP Trunk. I can establish connections to the outside world, but seemingly can't get it to work routing calls to the internal phones.
I'd be happy about any advice regarding the dial-peers.
I've currently configured 4 dial-peers - two of them (Internal to External) are working fine, as described. But for the External to internal connection it does not work out. Troubleshooting for ccsip messages shows, that there are sip invites coming in on the voice gateway from the ISPs SIP trunk, but are not forwarded to CUCM.
Current Dial-Peers: (1 incoming from CUCM; 2 incoming from ISP; 10 outgoing to CUCM; 11 Outgoing to ISP)
dial-peer voice 1 voip description CUCM-VGW --- incoming --- session protocol sipv2 incoming called-number 0T incoming uri via 2 voice-class sip bind control source-interface GigabitEthernet0/0/1 voice-class sip bind media source-interface GigabitEthernet0/0/1 dtmf-relay rtp-nte codec g711alaw no vad ! dial-peer voice 2 voip description Versatel-VGW --- incoming --- session protocol sipv2 incoming called-number 004930213089T incoming uri via 3 voice-class sip bind control source-interface GigabitEthernet0/0/0 voice-class sip bind media source-interface GigabitEthernet0/0/0 dtmf-relay rtp-nte codec g711alaw no vad ! dial-peer voice 10 voip description VGW - CCM --- outgoing --- destination-pattern 004930213089T session protocol sipv2 session target ipv4:10.5.42.200 voice-class sip bind control source-interface GigabitEthernet0/0/1 voice-class sip bind media source-interface GigabitEthernet0/0/1 dtmf-relay rtp-nte codec g711alaw no vad ! dial-peer voice 11 voip description VGW - Versatel --- outgoing --- translation-profile outgoing POTS-OUT numbering-type unknown destination-pattern 0T session protocol sipv2 session target sip-server voice-class sip bind control source-interface GigabitEthernet0/0/0 voice-class sip bind media source-interface GigabitEthernet0/0/0 dtmf-relay rtp-nte codec g711alaw no vad
Looking forward to any advice in regards of this.
All incoming SIP Invites from the ISP Come in as
To: <004930213989XXX@172.17.17.4>
Kind Regards,
Chris
Solved! Go to Solution.
01-22-2018 04:00 AM
01-22-2018 02:56 AM
01-22-2018 03:21 AM
Hello Rajan,
Thanks for helping out.
I fail to see how this is going to match Dial Peer 11 instead of Dial Peer 10.
Debug voip ccapi inout is not coming up with anything for the failed call (also - there is no signaling heard on the calling phone)
Debug ccsip messages output:
CUBE#debug ccsip message SIP Call messages tracing is enabled CUBE# *Jan 22 11:21:55.895: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Received: INVITE sip:004930213089100@172.17.17.4 SIP/2.0 Via: SIP/2.0/UDP 172.17.17.1:5060;branch=z9hG4bK55c07f6d9414e49b3 Max-Forwards: 70 From: <sip:443039111@172.17.17.1>;tag=712123059e To: <sip:004930213089100@172.17.17.4> Call-ID: 272b6dc8e40ca463 CSeq: 1190631592 INVITE Allow: ACK, BYE, CANCEL, INVITE, NOTIFY, OPTIONS, INFO, REFER, REGISTER Contact: <sip:443039111@172.17.17.1:5060;transport=udp> P-Asserted-Identity: <sip:443039111@172.17.17.1> Supported: replaces User-Agent: Trinity 3.x M5T SIP Stack/4.2.14.18 Content-Type: application/sdp Content-Length: 218 v=0 o=MxSIP 0 277 IN IP4 172.17.17.1 s=SIP Call c=IN IP4 172.17.17.1 t=0 0 m=audio 6360 RTP/AVP 8 0 101 a=rtpmap:8 PCMA/8000 a=rtpmap:0 PCMU/8000 a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16 a=sendrecv
Obviously, these invites are coming in a couple of times :)
Christoph
01-22-2018 03:31 AM
01-22-2018 03:50 AM
Sorry for the wrong info, was a typo.
All I get is Invite messages for quite some time and at some point the call disconnects, I do not see any message regarding this on the voice gateway.
Well, I Want to forward the complete number (i.e. 004930213989100) towards CUCM and just can't wrap my head around the fact, that this is not working with the dial-peer provided.
Chris
01-22-2018 04:00 AM
01-22-2018 04:09 AM
Thank you so much for the last reply. Toll Fraud prevention it was. Checking the trusted Networks and addresses showed that there was a typo in there, which did prevent the call routing.
Thanks a lot and have a great day,
Chris
01-22-2018 04:12 AM
