Outgoing calls in CUCM via SIP
shafjawaid
Hi, my network drawing is attached. i have SIP and SCCP phones in my network, i am using MGCP gateway. i am able to direct my SCCP users to outbound calls / interfaces by using route patterns. however i am unable to do so for my SIP phones. SIP Phones are able to receive calls from outside / pstn. kindly help me in making outbound calls from my SIP Phones. Thanks
Jaime Valencia
SIP endpoints use the same routing logic and elements as SCCP phones, troubleshoot as if they were any other phone and start b making sure calls are making it to the GW, if not, then go back to CUCM.
java
if this helps, please rate
Whats the error you are getting when dialing out ?
Could you please collect following for the test call from SIP phone and share ?
debug voip ccapi inout
debug mgcp packet
debug mgcp events
debug voip vtsp all
debug vpm signal
Please rate if you find this helpful
Thank You
Balram
