CUBE/CUCM Blocking based on CNAM
Chester Rieman
Hi ALL -  I have a customer that wishes to block calls based on certain CNAM(Caller-id) strings.  I have a LUA script that does this but unfortunately on the cusomer CUBE, they are sending some calls to CUCM and have other dial-peers sending calls directly to CVP so I need to explore other options.  I was able to create a SIP profile that changes the calling number to 7654321when the call hits the incoming peer.
 request INVITE sip-header Remote-Party-ID modify "\"CNAMstring\"(.*)<sip:(.*)@(.*)>" "\1<sip:7654321\u01@\3>"
Now the tricky part is that at this point the call is in the middle of the CUBE and needs to match an outbound dial-peer towards CUCM that will block the call and for outgoing peers on CUBE I can only match on destination.  I attempted using a translation rule on the outbound peer:
voice translation-profile call_block
 translate calling 5
but since this is an outgoing dial-peer, it does not work,  since this mechanism is looking for an inbound call.  I also checked into using a cor list which would probably work but I'm trying to keep this as simple as possible.
The other method to do this would be to reconfigure call routing to route all calls to CUCM and use the LUA script.  Just wanted to check with the community if there is a better way of doing this at the CUBE.  Any feedback is appreciated.
5 Replies 5
I am not 100% sure that I understood what you are looking for. But you can
create a DPG which can lock incoming dialpeer with outgoing dialpeer.
In this case create an incoming dialpeer to perform the translation and
create an outgoing dialpeer with destination match .T.
Assign the outgoing dialpeer to DPG voice class and assign the destination
on the incoming dialpeer as DPG.
In this case, any call hits that dialpeer as incoming will go directly to
CUCM after translation regarless of the called number.
Dennis Mink
theoretically, if you can change the CNAM string, you can manipulate the called number into , lets say "97654321" right? if you can achieve that you can match it on an outbound dial peer using destination pattern "97654321" and block it on cucm.
Please remember to rate useful posts, by clicking on the stars below.
R0g22
translate calling 5
This works on inbound only. You need to use reject rules and use "call-block translation-profile incoming" on the incoming dial-peer.
Hi ALl thanks for the responses.
Since the call already arrived at the CUBE and I need to block it from sending the outbound leg , I can't block incoming - I surely would not be posting here if it were that simple.
I ended up putting a tcl script on the inbound dial-peer that rejects the call for specified CNAM string.
ugly, yes
kludgy, yes
