CUBE-E 3945e - CPS
AshG
Level 4
Level 4
Where will i find the rated CPS for CUBE-E using 3945-E hardware.
All documents I can find only states that 3945-E supports 2500 Simultaneous calls but  no mention of CPS.
Nadeem Ahmed
Ashish,
Did you check the below link
http://www.cisco.com/c/en/us/products/collateral/routers/3900-series-integrated-services-routers-isr/data-sheet-c78-729824.html
Br, Nadeem Please rate all useful post.
Nadeem Ahmed
Ashish,
Cheers Nadeem,
I was focusing on CUBE documentation. Router Datasheet does have the details of CPS.
Hi all,
I am looking for same information for 4451 routers, but in mentioned document there is no info for CPS of 4400 series. Where can I get that information ?
